Seeking advice.....
I have a Junkers 6434/178 ATLANTIKFLUG watch that I've now had for little over 25 plus years now.  It is a good watch and enjoy wearing it (that is whenever I do decide to wear it) still keeps excellent time, etc.
The problem that has slowly been developing now (maybe the last couple of years or so) is that the inside of the crystal has slowly starting to become foggy sort of. More than likely I am assuming that it is a bit of moisture that has possibly set in?
The crystal itself is in excellent condition. The crystal has no deep scratches, cracks, chips, etc. nor is it lifted and the back of the watch has the tighten screw down cover.
I have not messed with the watch itself as far as opening it up, etc. I've just left well enough alone to it. Though as previously mentioned I have worn it occasionally.
This is where I am seeking advice or direction as to how to approach this particular problem as to why or just how the inside of the crystal fogs up.
The dial and still be seen and the time can still be seen as well it's just that it has started to annoy and distract me and has become bothersome.
I would like to stop this from happening.
Lastly anyone here on the forum familiar with the Junkers brand of watch?
Any and all suggestions and recommendations are appreciated.
Thank you in advance.
1476237712_Junkerswatch.thumb.jpeg.4e94a14aee0706dd079f7f4d7aa03399.jpeg1628233685_JunkerswatchII.thumb.jpeg.ed0da329c6b228d626f7a2a7f5479369.jpeg192696280_JUNKERSwatchlume.thumb.jpeg.dbb730116269851a621285c8c92874d6.jpeg1899889093_Junkerswatchalligatorstrapandalligatorbuckle.thumb.jpeg.c4f519118ff22a84a1634c8da22b7686.jpeg256010496_JUNKERSwatchwithcustomalligatorstrapandbuckle.thumb.jpeg.5c5fadfd3b20637623d8f81cb42786d7.jpeg
 Leave the watch face down under sun light for several hours to get rid of any moisture inside it.
Moisture rusts the base metal that parts of the movement are made of.
Keep the watch away from water moisture, which I presume has ingressed through the case tube due to worn crown seal.
Remove mov.t, dry up the inside of the case with an hairdrier, inspect for cleanliness, inspect and replace as necessary crown and caseback gaskets, lubricate these with a bit of silicon grease before reassembling. Then do a condensation test which is warming the whole watch just a bit then let a couple of very cold water drops on the crystal, that does nor replace a pressure waterproofing test but at least tells you right away if all moisture has left.
  • Thanks 2
8 hours ago, jdm said:
Then do a condensation test which is warming the whole watch just a bit.
Interesting test.
Question , How do you warm the watch and how much in terms of degrees?
Clever. My daily driver has very little in the way of water resistance (pilots' watch), and it's managed to have water ingress on two occasions. Both of which were when a slight stream of water ran over it; once water running off a tarp that had been rained on, and the second was something work related and tap water spillage or something. Both times, I just opened it up, put it under my tray cover with the corner raised to keep any dust out, and I just let the dry mountain air do it's thing for a few hours. I didn't think to add heat or test anything. I resealed the main gasket with silicon the first time, and the secondary (probably too much) the second time. Both times, I noticed the moisture inside the crystal immediately, and acted within minutes, so I'm hoping I staved off any significant corrosion damage. Next time (should there be a next time), I'll definitely apply heat and test.
Yet another example of the dichotomy of watchmaking where high meets low. You don't have a pressure tester (high tech), so a decent proxy is to just warm it up and put a drop of cold water on it (low tech). Fascinating art/science...
Edited by spectre6000
Thanks to everyone who has posted and given very good info, advice, etc. I appreciate it very much.
I suspected that just maybe any gasket(s) that the watch may have would probably need to be replaced?
I was hoping that would not have been the case but oh well.
I take it that just about every mechanical watch will have a back gasket as well as a Crown gasket?
What about the top cover?.....do all watches have a top cover gasket as well?
Edited by Orhorolgy
You are likely to have got away with zero damage to the movement itself, I don't know about lubricants though.
If you are obssesive like me, a goog clean and lube is in the order.
Not [i]every[/i], but practically every. As for a top cover gasket, it depends on the case design. There are some that [i]only[/i] have a top cover gasket (these often won't have back covers, and sometimes deceptively so), some that only have a back cover gasket. Tough to say from the photos, but it's not unlikely.
@Nucejoe, Yeah. I bought it NOS. IIRC, it was 6 years old when I got it, so already due a service. I've been trying to get to the point where I'm comfortable tearing into it. It's a 2824-2, and ETA parts limitations for randos like me, so I don't want to risk screwing it up too badly. I did some major office rejiggering yesterday, and while I still have a bit to go, I'm hopeful that I'll be digging into a number of movements very soon! My office was the dining room pre-pandemic-two-people-working-from-home-and-also-we-had-a-baby-and-my-office-became-a-bedroom paradigm, and we finally realized that under quarantine, no one is coming to have dinner any time soon. Additionally, I finally found someone who could sell me a semi-temporary sturdy shelving unit in a safe and economical way, so I now have full run of the dining room table as a work surface rather than a junk repository. Just need to finish clearing a few things out of the way... Coming soon!
 I think the movement in OP's watch is a Malnija a Russian made and not the original Eberhard, Malnija best run as much as you have energy to wind so it polishes itself. Though water damage at microscopic level is bad too, I don't think its a big deal with Malnija.
ETA movements are much finer made and are real susceptible to moisture damage.
My neighbor had me replace a glass crystal in his Invicta.  I posted about this on this forum.  In summary, it fogged up when he would shower with it.  With guidance from these fine members, I removed the crystal and purchased a new nylon case ring (that interfaces with the crystal) and a new gasket for the back.  Using one of those silicone applicators, I coated the gasket with silicone.  With the new nylon insert and new back gasket, the problem was solved.
I used my waterproof tester to discover where the leaks were.
    • Beginner here. Of about 60 watches I’ve serviced and repaired, I’ve broken a pallet pivot on three, always during disassembly, and usually when the old oil has transformed to glue. Each watch was Swiss, in case that makes a difference. Here’s what happened in each case: - unscrewed the pallet bridge or cock - gently inserted a screwdriver in the  slot under the pallet bridge or cock - gently but firmly rotated the screwdriver, avoiding a forwards force on the screwdriver. If alignment pins stick, the cam action is alternated back and forth between back corners of the plate. - heard a small but horrible click. Is there a special tool or technique for safely lifting the pallet bridge? Should everything be soaked in naphtha before beginning disassembly if there’s any sign of old oil gluing parts together? Thanks! Rob
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
