I joined this forum for advice regarding watches & clocks my husband and I own.  I probably won't be fixing watches but I have a grandfather clock that hasn't been running for at least 50 years and will give that a go.  I also have in my garage some tambour clock cases from one of the old furniture factories in the Boston area where one of my grandfathers or father worked at. Could be Irving Casson. Might be nice to create some finished clocks as presents.
