  On 2/4/2022 at 2:17 PM, HectorLooi said:
These are oil sink cutters. They are for countersinking pivot holes to create an oilsink.
Expand
I'm sure this makes perfect sense to most people, but I'm not totally following. Is this for unjeweled pivots? Are they used like a spoon drill?
They are used to countersink any holes, not just for making oil sinks in unjeweled holes. As you can see in Dean's video above, he has given the jeweled centre hole a decorative chamfer around the jewel, and he has also chamfered the screw holes. It makes an attractive contrasting surface finish and a neat transition from one surface to another.
  On 2/4/2022 at 2:03 PM, Juec said:
Hi,
Can anyone tell me what these tools are please?
Thanks in advance
Julie
Expand
These are for rounding the edges of jewel settings or jewel holes on plates. You simply stick it into the hole and then twist it in a circle grinds off the edge without an issue You simply stick it into the hole and then twist it in a circle grinds off the edge without an issue
