10 minutes ago, jdm said:
On the other hand probably the ideal all-in-one quartz tester doesn't exist.
I am in the process of building a custom tester based on the Accutron 600 test set.  I choose the 600 because I have a pristine 700 and dont mind hacking the 600.  I like the test set because of the huge 25ua meter!
I am designing a variable battery source using a miniature digital volt meter mounted on a 3D printed module that plugs into the hole in the 600 test set (where the leads are stored).  This is not a "does everything" tester either.  It will let me test for low and high battery voltages, and also test pulse current.
The picture shows the current state of the module--basically got the 3D print done.  The electronics will be trivial.
The combination quartz watch testers  are as jdm said over priced   I got hold of one and took it to bits, the cct board is or was then cobbled from somthing else to do the job and the wiring was terrible as was the soldering. I threw it away and only saved the transformer (line release) and built it to another case Its still working which is more can be said for the rest.  I tracked the originol to India but got no response from the people who made it, which was not surprising.
The hard part for me is the mechanical features.  Making probes, holder, mirror and all in a nice station. I am thinking about buying a mini mill to make parts for things like this. Crazy...I know
Some good ideas on the mechanical aspects for sure.
His circuit is overkill IMO. I have not read or tested to confirm, but I would expect almost no real current drawn by a watch. Therefore the source resistance is no big deal. Using regulators to achieve 0.001 ohms source resistance is not necessary. What is important is an extremely low ESR capacitor in shunt with the watch.
I am planning on using a shunt regulator and a resistor divider with a pot...a very simple design. At least, that is where my head is now.
Another thing I learned from the docs is the need to go all the way down to 0.8 volts.
Edited by LittleWatchShop
There were even more simple probes, all you need imo.
Just an U-shaped wire, pointed tip on one end, 2 mm plug on the other:
Usually a quartz is tested contactless, without opening the watch. A piezo receives its 32 kHz vibrations, processed by a narrow band (quartz filter) amplifier.
Frank
Edited by praezis
  • 4 weeks later...
On 9/7/2021 at 4:28 AM, Plato said:
If money were no object then I'd buy a suite of Witschi equipment.
However, the closest I can afford is what I picked up on ebay a few years ago. A Portescap 5007. It has three probes so one for +V, one for gnd and the other to take measurements. I just had to make some leads for my PSU and scope. Under £30 including the connectors:
IMG_0004.thumb.JPG.b8b40bb89a5d53248b02fa68997846f1.JPGIMG_0005.thumb.JPG.665f5047b5f915ce9a41264073a05549.JPGIMG_0006.thumb.JPG.7ebebc27d5a00f0300c9a07f92d79433.JPGIMG_0007.thumb.JPG.ff3444585df34c17209bc84aec3b3212.JPG
@Plato, what is the diameter of the viewing window?
@Plato, is the mirror in your setup freestanding, or attached to the workstation?  I have printed a wedge to mount a mirror.  Not sure if I need to attach it to the workstation.
Do you ever test movements, alone, or just cased movements?  I am just pondering the movement/case holding features.
I discovered that this thing NEEDS LIGHT.  I cannot see the face of the watch on the glass because it is too dark.
Using a COB LED that I salvaged from a light bulb (one of many) and a dual 2032 battery holder/switch, I cobbled together this solution.
7 minutes ago, watchweasol said:
Hi Thats nifty all I use is a mirror and a frame with a bit of glass on the top, maybe should inprove it now looking at yours and do a better job  .
Do you have a 3D printer?  I can post the stl files.
Alternatively maybe I could design and print one to fit your glass and mirror and swap for barrels.
Hi  My Nephew has a printer and he does bits for me when I need them  thanks for the offer though.    regarding the barrels, The mougin movement, size are approx  36.5 Diameter X 25.5 depth and the width of the ring teeth is 3.5 depth I have a couple of barrels.
This is what I measured the other day while still in the movement.  Looks like what you have is a little different.
Strategy change.  For now, I wanted to have a variable voltage source to power watches.  This is not integrated with anything.  Just a standalone voltage source with readout.
That is a 10-turn pot, so I can make fine adjustments (though that is not necessary).
Not the best 3D print, however.  My printer has been giving me a few fits here of late.
  • 4 weeks later...
  • Similar Content
    • Thank you. No value to me, and I guess not much value to anyone else either - just practice fodder as far as I see them. Ingersoll might make a nice watch to wear if I manage to service it. Benrus, I suspect, is too far gone in terms of case and dial - no cheap ways of getting them to decent looking condition? I wonder how these old movements compare to modern Chinese ones? Probably not favourably, even if there's nothing broken in them? Progress moves on? I've got an old Slava that I'm quite attached to, so I won't be learning on that one.
    • Welcome to the forum. You're best starting with something that you know runs well and keeps good time. That way when you've stripped and service it, any problems are due to something you've done.
    • Welcome to the WRT-Forum! Sorry to say it, but you’re very likely to break or lose something when servicing a wristwatch for the first time — I’ve been there! So, if these watches have any value to you, don’t attempt to service them as a beginner.
    • In writing "shimming the staff" I was alluding to the idea trailed in the above referenced thread of inserting a hair along the staff which, as the discussion there covered,  could result in some eccentricity. By making a (more or less) complete cylinder I was hoping to avoid that problem. Don't tell anyone, but needing a very ductile metal to do this by manipulation at such a small scale, I used a piece of an empty Tomato pureé tube! It occurred to me that the material's ductility(?) would also put less stress on the RT in forming a sufficiently tight seal. Anyway, that's how I avoided the temptation to use glue. No doubt your punctuational response to this confession will be "!!!" !
    • Hi All. I would appreciate some advice for a complete newbie on getting into watch servicing - nothing serious,  just as a fun project. I've got a thing for hand-wound watches and would like to bring an old watch (or two) back to life, so looking to learn to do a strip-clean-oil-assemble cycle.   I've toyed with this idea in the past (years ago) and picked up a couple candidates to learn on, but never found the time for them.  One is an old Ingersoll, swiss-made 17 jewels. It seems to wind and tick. Casing, dial, glass are in great shape, so looks like a good candidate to me for the first service. The other is a Benrus DR23. It winds and makes a few reluctant ticks, but then seems to stop. Casing looks like a complete gonner, and the dial is in pretty poor shape too. If the movement is not broken and just needs a service, I wonder if there's any possibility of getting a cheapo Chinese casing & dial to fit this movement in, or is it extremely unlikely to be the right size?   For a start, I want to strip & assemble a movement, perhaps a dozen times to build up the basic parts handling skills. I see that online advice is to buy a Chinese-made ST36 for this purpose. Can I just go at the Benrus or Ingersoll instead, or does it make more sense to get a cheap ST for this? Thank you.
