Tommy Bahama Battery
Hi all,
I recently got a Tommy Bahama Decade (TB1017) for a battery change.
I had to remove the bezel around the crystal and the crystal ring.
I'm still unable to remove the movement.
The case is one piece with no back.
Tried to find something on line.
Called a company and they said it would have to be sent to Precission Time in Utah.
I'm guessing it has a two part stem, similar to some pocket watches.
Is this correct, and if so, what is the proper way to disassemble the stem and get to the battery?
Thanks in advance,
Dave
Is this correct
It does sound like it will have a split stem in which case a very firm pull will be required to remove it. Occasionally it is possible to turn the stem to a position to allow the movement to fall out.
As Clockboy says pictures may help identify the solution.
Sorry about the delay,
I've had a lot of things going on since my last post.
Geo may have hit on something. I tilted the case and the movement fell out.
I've included picts. I had some trouble directing the focus on certain areas.
When reassembling, I tried to align the keyed stem parts and drop the movement in.
It worked.
Thanks all,
Dave
P.S. Let me know if the quality is OK.
  • 6 years later...
I know this is an ancient post, but my dad just handed me this exact same watch tonight and he wants me to replace the battery.   So to remove the bezel and crystal, did you just use a case knife?  I can feel it has just a bit of a lip when I feel it with my fingernail, but I'm afraid I'll roll that little edge if I start prying at it with a case knife.   I don't see any indentations or anything that shouts "start here" on it.  Also I'm not real clear on how the stem came out in the post above.  Does it not need to come out to get the movement out?   Did it just require tilting the case the right way?  I'd hate to get the crystal off and still not be able to get the movement out.  Any help is appreciated.  It's a nice watch, being silver and all.. I'd really like to get it going for him again.  Thanks.
Check topic below for a discussion on useful opening tools, as an easier and safer alternative to working slowing around with a sharp blade.
    • The epilame under the oil will also be removed
    • If we use the rub-off epilame method of pallet stones (run dry for a few minutes before applying the epilame) where will the oil go/be transported when it is pushed away from the impulse surface by the escape wheel teeth? Onto the epilame-treated sections of the pallet! Once the oil has been applied/transported to the epilame-treated sections of the pallet where will it then go? Nowhere as the oil will remain on the epilame. So, perhaps the run-dry method defeats its intended purpose leaving the pallet impulse surfaces dry!? If, on the other hand, we do not remove the epilame from the pallet stones where the escape wheel teeth come in contact with them I'd expect more oil to remain where we want it and need it. Yes, I agree, that is the question, and my gut feeling tells me that is exactly the case. Epilame was created to have an adhesive trait and the oleophobic property is just a side effect.
    • Might that be the viscous nature of oil resisting gravity H  ,  we have been comparing water and hydrophobic surfaces which are similar in principle but water is much less viscous than oil. I guess what we trying to discover is if epilame also has an adhesive trait as well as being oleophobic. Plus the oil dropet has very little mass for gravity to work on, like watching tiny water beads that can grip onto vertical glass until they are connected together to increase their mass then run down. Gravity isn't the only factor at play when oil is placed on pallet stones. The oil receives a lot of bashing that may push it out of position ? Thinking about it if the oil stays in position for 10 minutes enough time for the escape wheel to scrape off the epilame , then  a walled in lubrication has been achieved,  the epilame is no longer beneath the oil ( possibly mixed into the oil )
    • But it also makes it seem less susceptible to gravity. If you place a droplet of oil on an epilame-treated surface the droplet of oil will still stay in place even if you then flip the surface from a horizontal to a vertical position. That is, the oil droplet remains anchored, and that's the purpose of epilame. If it was just a matter of creating an oleophobic surface we could probably use other, less expensive, methods!? I don't know @Waggy but my gut feeling tells me you're spot on (pun intended!). I believe the oleophobic property is a side effect of epilame which is designed to keep the oil anchored.
    • Saturday morning 27/4 Sunday evening 28/4 Monday evening 29/4 Floor has a drain in the middle so I am hoping that there is very little fall on it, if any. Room is about 2.5 x 2.5 metres square. Can only use about 1/2 of one wall on the right of the pictures which has a sliding glass door in it. And only about 3/4 of the wall to the left of the pictures as it has the door to the house in it. Progress. 🙂
