I picked up a dozen or so hairsprings on ebay--the wild wild west of material suppliers.
A couple were rusty and a couple were bent out of shape.  The rest are usable.
Now I want to know the best way to store them so that they do not rust.  Obviously, inside, climate controlled house, but I wander if immersing them in oil and putting it back in the paper wrapper is a good idea.
Here is an example paper wrapper.
No it is not. Not even large mechanical parts are wet in oil for storage, just a different wrapping paper was/is used, Cosmoline in the US, different names elsewhere. That wrapping leaves such a stubborn sticky residue that cleaning it is a big job, and would be totally disastrous for the most delicate item, that is an hairspring exactly.
Look at how it was done in the the old times, that light paper is probably rice paper. It is acid free and has good absorption of humidity or fluids. If your parts come in that already leave them there, or rewrap with your own rice paper. For further peace of mind store together with silicagel sachets, and that's all.
7 hours ago, jdm said:
... Cosmoline in the US, different names elsewhere. That wrapping leaves such a stubborn sticky residue that cleaning it is a big job, ...
... For further peace of mind store together with silicagel sachets, and that's all.
Re silica gel desiccant: I do this too.  For small parts which I don't wish to become corroded, I leave them in their original wrapping if it looks safe, and I keep a couple of desiccant packets in the parts drawer with them.
Re Cosmoline: JDM is not kidding.  You would not want to clean Cosmoline off watch parts!  My own brother brought me a beautiful Elgin pocket watch which would not run.  He'd just bought it, but he didn't tell me where from. It had a grade 241 movement, into which some idiot had sprayed a whole lot of Cosmoline, then stored it away in a wooden box for several years.  After I removed the balance and lever, I went through many soakings in alcohol with the other parts.  I had to use pegwood and a soft brush; that stuff was between teeth, between pinion leaves, in every little nook and cranny.  It was a long, long cleaning effort, sticky and awful.  Please don't ever consider putting that stuff on a watch part.  It's not the great idea that it may sound like.
(On a positive note, that movement had no corrosion at all anywhere.  But then, many watch movements can stay clean without Cosmoline, so there's that.)
Edited by KarlvonKoln
Here in the UK there are plenty of covid19 lateral flow tests being used, including myself.  Each test kit has a small package (1cmm x 2cmm approx) of silica gel.  I keep these and use for bits that I want to keep rust free.
5 hours ago, oldhippy said:
Anti rust paper is what I used wrap them in that.
That's a great idea.  I can look for some online, I suppose, but is there a particular kind of store that would stock anti-rust paper?  Hardware store maybe?
15 minutes ago, oldhippy said:
Plenty of places if you look on google.
There are indeed, and it's not too pricey at all.  I think I'll just order some now, so I'll have it when I need it.  Thanks  for the idea OH.  Don't know why  it didn't occur to me before.
Something like the anti-tarnish watchmakers paper that otto frei sells?
If you are putting them in a sealed container you could throw in one of the oxygen absorber packs marketed for food storage, too.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
