15 hours ago, Myron62 said:
Anybody know anything about Rone watches.
If you type that in Google, the 2nd or 3rd hit are (other) forum topics about these.
Anyone recognise the movement?
It's a FHF, which exact designation I can't say because they changed bridge layouts all the time and even custom marked as this one.
I recognise the movement, yes, but not able to recollect the precise calibre. I’d agree that it’s likely an FHF Swiss movement. Yours is in a quality 9ct gold Dennison case, hallmarked in Edinburgh I believe. I’ve restored about four Rone watches in the past couple of years and they’re very nice vintage watches, often with attractive dials like your one. Well worth servicing and keeping in memory of your father in my opinion.
Edited by AdamC
Great, i'll give that a go
Agreed, its a good looking watch. Now i know its an FHF movement, thanks.
The Rone fifteen above is a very distinctive and attractive looking model.
I have 4 mens vintage Rone watches c1950s. These use ETA 2370 (manual wind) and ETA 2451 (auto) movements.
Some history of the brand can be found online - extract below:
Rone watches were listed (by Pritchard) as Rone Watch Co. SA, Bole (circumflex on 'o'), Switzerland, and the same source mentions that they were listed again from 1966-1973. Rone watches were seemingly in production from the 1940s (1920s more likely based on case hallmarking) until the middle of the 1970s. A variety of models are found branded, Rone, including some in solid gold, which can have the maker's mark "RWC" or "RWCo" for Rone Watch Company. In connection with the designation, RWC, there has been some confusion with Rolex, but Rone watches are not related to Rolex in any way.
I’m new to this subject, my speciality was antique clocks and more recently drifted on to pocket watches.
The movement shown is almost identical to the Waltham pocket watch. This was the biggest watch manufacturer in America at the turn of the 20th century.
The good thing about walthams is that the main parts were all given a unique stamp /number ruling. You could then tell it was genuine
  • 4 months later...
I had a look on the ranfft site and it does not appear to match up to a FHF 26, but it may be another model in their range. I have an (apparently) identical vintage Rone Fifteen movement on order and will check it for makers’ marks once it arrives.
Seem to have caught “Rone Fever” this summer and have just re-cased a Rone Seventeen model 1200 movement. This movement was bought “working”, and as I already had a spare case of the right size, relatively little work was required initially to get a serviceable watch. However, the stem had to be extended as it had been cut off, presumably when someone removed the movement from its old case in a hurry. I will report on the exact movement model number later when I remove the dial for light cleaning (probably FHF 26 variant).
Confirmed as an FHF 26, as in the Fifteen, but the 17 jewelled version of course.
Unfortunately supplies of reasonably priced 33mm NOS cases seem to have dried-up at the moment, so prohibiting further Rone movement re-casing projects.
