Hand Winding Mainsprings...
I am saving money for mainspring winders, but I'm having trouble winding with finger cots. I wind them with cots and they always end up with bits of rubber stuck in them.
Should I forget the cots, wash my hands, and use them with bare fingers?
I had a watch maker sneaking through my bench and he said, "Man, I'm so sorry!" I said, "I know my tools are used and limited!" He said, "No, those condoms are really small!" I don't think he uses them at all, but I didn't ask because he caught me off guard. Lol
I don't know about this, you can clean your hands all you want, they're still going to sweat and excrete oil just as much. Finger cots are great but I can see your point about hand winding with them, can be problematic. Not sure what to suggest.
(and yes, with finger cots, many a time with colleagues and customers I've had to smile and say 'it's not what it looks like', I try to make light of it, because I just wouldn't want to work without them)
Edited by Ishima
I only have a small set of right handed winders ,so often hand wind. I give my hands a thorough clean and scrub with a nail brush then once dried off roll rodico around the tips. Once the spring is in I roll rodico over the open barrel end and clean the closed barrel with rodico with cots on. As I suffer from springlexia I always photograph the spring in the barrel before I remove it as I have been known to refit them upside down. :thumbsd:
My friend uses spray on plaster dressing (it forms a thin skin over the area applied) for cracked skin.  I am going to do trials on how well this stays in place and how soluble it is in oil, water etc.  I have tried it on a wound in the past it it was quite difficult to remove so maybe worth a punt.
Hi Canthus,
Dry your hands off ...meaning no moisture. Wind your spring in. Rinse in zippo fluid. Oil as you would normally but use your oiler to spread the oil over all the visible edges of the spring.
If you're replacing with a new spring, its even less as a problem as they are are made of an alloy which resists rust well. If you are reusing a blue steel mainspring then moisture is not really your problem as these springs lose their 'springiness' over time and will need to be replaced.
Anil
What if I washed my hands and then proceeded to wind and lube the mainspring by hand, but instead, once the barrel is closed I use a q-tip with one dip on it and give the outside barrel a gentle bath with the q-tip and dip?
I have to take a picture too!
Edited by diamondslayer
Outside of the barrel is the least of your problems... You can use a qtip/dip but even a wipe with a clean dry cloth will work if you use rodico to get the fibers out of the barrel teeth.
The main thing is to avoid moisture and other contaminants inside the barrel itself.
Anil
    • Many would disagree: https://www.rohm.com/products/faq-search/faqId/234 https://uk.farnell.com/c/semiconductors-discretes/transistors/bipolar-transistors/pre-biased-digital-bipolar-transistors https://uk.rs-online.com/web/p/bipolar-transistors/8232832P?gb=s https://uk.rs-online.com/web/p/bipolar-transistors/0580240?gb=s (RS don't have a specific category, but over 1000 "digital transistor" items).
    • Thanks, ManSkirtBrew.  I started looking for a setup like yours and ran across this.  It was about half the price of the JKA Feintaster (depending on what auction you were in), and it's a Bergeon.  I bought it because I thought the price was fair (eBay - Buy it now), and I'm a sucker for vintage tools. It also has a table, so it should be easy to use for measuring jewels. I wonder if the the contact points can be changed out. Bergeon seems to manufacture new tables and accessories for the contemporary dial version. What do you guys think of it? I'm sorry this post seems to have taken a detour. I'm new here so let me know if I should start a new topic.
    • This is a flying cutter, usual one. The cutter itself is shown in the pictures in the first message, it is made of broken tungsten carbide drill bit. I asure that all the angles of the cutter are as they should be. I have video - little older one - that I made when onse making the same kind of winding pinion for a Poljot 2200, which is even smaller than this one. It is not easy to see in the video, but the tool rest moves about 1mm towards the object in Y direction and then returns back untill cutter is rotating. Then the spindle is rotated one tooth ahead and everything repeated untill all teeth are cut.
    • After a bit further research could it possibly be an AS 970?
    • Latest project was a non-running ebay purchase with an FHF70 movement. I stripped and cleaned it, reassembled it, and got it running. So far so good, nothing damaged AFAIK.  I was oiling the top jewel on the balance (the one in the cock) which was a slightly unusual shock setting. I removed the spring (3 leaves) which was part of a chaton holding the cap jewel. This left the hole jewel behind which I retrieved with rodico and then lost it. I was taking it off the rodico, very gently as I thought, with tweezers, and then it just disappeared.  Fast forward a week, I got a donor movement, non-running, with the plan to just take the shock jewel that I’d lost. It was the same movement but had standard incabloc settings, and was steel rather than copper/brass.  I changed the cock and balance complete and it ran, not very well. I switched the lower jewel setting, cleaned and oiled both jewels and the replacement balance. Without the pallet fork the balance swings very nicely with a puff of air. With the fork in place, balance out, it flicks side to side nicely with power in the mainspring.  Put them together and it doesn’t run. The impulse jewel sits in the fork and it stops.      Any suggestions how I proceed? In case you didn’t follow that I have 2 FHF70 movements, nothing broken as far as I can tell, but mixing up the balance wheels and jewel settings results in a non runner.
