Quick Advice :) Timegraph
Hey guys, yes its me .....again :)
After Reassembling a rather lovely Zenith movement i put her on the timegrapher to see this result ?
I was thinking maybe the escape wheel is running untrue but i could be way off the mark. Can anyone give me some idea as to where to look given the state of the above graph ?
It is rather erratic, and although i can read most errors im a bit unstuck/unsure with this one ( scratches head furiously ).
All help greatly appreciated as always :)
Have you tried to demagnitize the movement?
Well worth a try, but I would have expected it to run fast rather than slow if it was magnetised.
Is the balance spring distorted an touching the balance wheel, has the escapement has been properly lubricated and are the balance jewels are OK?
I have de-magnetized the movement and all parts seem fine, even the roller jewel is almost perfect between the pins ( ? ). The jewels are also fine, which is why im confused to the lines ?
The hairspring is not hung up nor sticky, the pallets are good, the wheel pivots are true. I get the feeling im missing something obvious but im lost as to what or where ?!?
I have looked over the thread on timegraphers thx ro63 but nothing there stands out to me :(
I will take the escapement apart tomorrow morning and inspect it under my microscope for a deeper look, also give everything a re clean in some degreaser. Good thought there Geo , did not think about the roller jewel being loose.
I never pick an easy job, when will i learn ha ha :)
Well after stripping the escapement down i discovered ( with the aid of my microscope :) ) there was some hardened oil/grease within two of the jewel holes ( balance and pallet ). It was quite stubborn but after a good de grease of the entire escapement the watch now runs within +- 20-30 secs and the beat error is down from 6.00+ to just 1.0 -1.1 , i can happily live with that for a watch that is 70+ years old :)
The watch originally was badly water damaged with alot of rust reaching nearly every part of the movement, so to have it running at all after the original condition i can say im pleased with the outcome. The timegraph result initially had me thinking it was a bent escape wheel pivot, but turns out it was just super hardcore crud , albeit micro hardcore crud ha ha.
Since i know you guys like your pictures i figured you'd like to see the watch in question, she just needs a new strap and then shes done :D
Dial Cleaned - Casing Polished - Original Hands
Zenith 10"'-1/2 - 2 - 9kt Gold Cased
a3d756b9-cc5e-4e08-ba10-7a40b3208b0c_zps
Funny to think that id overlook one of the basics of it being just dirt.... ( slaps forehead )
Thanks though guys :) U R Awesome !
I'm well pleased you resolved the problem Mr Beat. It certainly got my grey matter into gear for a while last night!
You should be very happy with the end result, because the watch looks gorgeous! :)
Thanks guys, she is a stunning but simple piece. Hopefully it will keep going another 70 years :)
I think from now on im gonna be using my microscope a bit more, i just figured that after going through two different cleaning machines and cleaning 90% by hand that all the dirt had gone, how wrong lol.
    • Yes: that's it exactly, right down to the break in the spring!!
    • I've bought brands like Citizen, Seiko, Titoni, Tissot, Roamer. Strange thing is many of them were using ST96 movements. I'm not sure if the ST96 is original to that model or whether it was a replacement movement.  All the watches with nice looking dials were obviously refurbished, after-market dials. And all of them had over-polished watchcases. Some of them had non-original hairsprings, rejewelled pallet forks, watch crystals that don't fit and glued in with a generous amount of glue. One of them was totally not working because the pallet jewel was loose to the point that it almost fell off. But the sellers were very nice. The seller of the non-working watch gave me a complete refund. Some of them gave partial refunds. I would say don't by luxury watches on the internet, regardless of the country the seller is from. Don't believe the "serviced by master watchmaker" statement. Have realistic expectations. ( Do expect the occasional complete junk.) Do expect to do a complete overhaul and major repairs. Otherwise, watches from Mumbai are great. For clocks.... I'm not so sure.
    • In 2020,I picked up an Orient Mako II online. It ran at +15 seconds per day and after 3 years of resets more than weekly, it was time to crack the seal and take a shot at regulating it. Not having a timegrapher, I used a spreadsheet to track the time, referenced the Canadian NRC website, wore the watch between adjustments, and used the back end of some tweezers to lightly tap the regulator daily until it ran to within one second per day.   Two months later, it’s still running to within 1 second per day when measured over a week or longer, while daily variations are up to 9 seconds per day. For my purposes, its overall stability is surprisingly good. Is this method of adjustment “better” than adjusting to 5 positions using a timegrapher, since during the adjustment period the watch is already in the environment in which it’ll be used? Rob in Winnipeg
    • Nice file  Just got old pocket watch in and tools,  can I get it back together or should I give up.  we'll see  thanks for the info
    • @HectorLooi Yes, I would say that Mumbai has the highest liquidity in terms used watches. How was your experience with these used watches and what watch brands did you buy used? I have always found the vintage luxury watch segment in India a bit shady. Quite a few are genuine watches with genuine matching parts but just not from the same one.
