Hi. Have just posted on the newboy section so at the moment my experience is down to Marks' great courses and investigating and repairing a few ,not so important movements. I have though decided to delve into my 645. Have put a picture up so hopefully it will show properly on the post.
As you can see it has had a life! Two months ago it just stopped so I am assuming a good clean and oil will be all that is necessary. I have had a good hunt about but cannot find any procedures so I want to just proceed with care. Can someone identify the top wheel for me(am presuming seconds but not sure). is it just a press fit? what is the top spring holding down? what to be careful of (apart from my own foolhardiness!)
Many thanks
Simon
If you are determined to do this yourself, and I would advise against it If you are not confident in your ability, then as you say, proceed with care. If you lose or damage anything, spares are expensive and hard to find. Also:
At every stage, make sure you know what you are doing and how to do it. Ask here If you are unsure.
Get the right tools for the job before proceeding.
Take lots of photos to remind yourself what goes where.
Keep the parts in functional groups before, during and after cleaning.
Don't rush.
Good luck!
Do you know when the last time it was serviced?
The reason I'm asking the question up above is modern watches typically don't stop. Vintage watches with organic oils can stop as the oils get sticky and things come.. The modern watches the oils tend to not get sticky and not sail watch can't stop but before assuming it cleaning and oil will help maybe you should see if you can figure out why stopped?
I've muscle attaching parts lists. But just because you have a parts list and you know the parts are available that are probably not available now and if they are available there going to be extremely expensive. Which is why as somebody above hinted at this is not really a good beginner's watch sort of? Sometimes and watch repair painful lessons are good like this watch has the potential of running as soon as we figure out why it's not running. But if in the process of you learning how to repair watches you break it can't get a replacement part then you learn important lesson of not to work on things you shouldn't yet.
Is the watch totally stopped not running at all? Can you wind it from the crown and will it start to run? Visually seeing any problems like this is a Older watch especially with the automatic components It is possible for them to wear out especially if there Metal on metal bearings which was common on early automatic watches.
Rolex_Rolex 635.pdf Rolex_Rolex 645.pdf
Hi and thanks for all the replies. I understand all your concerns and appreciate the thought but I did not do these courses just to play about. I have already played/practised with many different movements and the time I feel is right.
Yes I will be meticulous, yes numerous photos will be taken(always do), yes I will ask if a problem arises and yes I understand the risk of breakages/spares etc. The auto wind mechanism has always been missing(if anyone knows of one or a contact I would appreciate it) so in fact it is already an incomplete movement and theoretically of little value. I would expect the case and dial are worth more. My set up is pretty good and the 5spoke puller was already on order from Cousens- appreciate the link though.
Just taken this photo and ironically the movement it has decided to spin again quite merrily. Had depowered it and wound it up again so as of now its under observation until further notice!
Watch this space
Cheers
Simon
 Its says timed in six positions, I guess thats the same as adjusted in six positions. It be real nice if you would check timekeeping in FU, FD, PU positions, to see how accurate adjustments still are , it'll give an idea of the level of expertise required for the task your up against. Overall if you perfectly handle the oscilator iand n particulare the overcoil, you should be alright, though pivots might have worn to the extent that can affect adjustments.
 Its a Chronograde  " of value"   at least technically  and thats what has made everyone here extra sensitive, one would normally entrust such grade movements to hands of a master watchmaker.
I usually put some lighter fluid on jewels, a whole droplet on the settings, it softens dried oil and momenatrely acts as lubricant, put some on escape teeth too, next,   immediately puff air to get the oscilator running hopefully  tg readings be somewhat valid then.
Good  luck pal.
Well, there doesn't appear to be anything especially challenging abouth the movement itself, just the consequences of a mistake are higher than before. I understand, you are ready to progress, so go for it. Get the movement on the timegrapher to assess its general condition, then get to work. Running it dry will only make it worse.
Did you notice in the pictures missing is the tinegrapher?
Then yes the watch really is timed to six positions it's a chronometer grade movement. So it should keep phenomenal timekeeping.
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&Rolex_645
The thing to do it be a keep an eye on eBay and see if one eventually shows up. Then the hope that it's not worn out.  I was looking at eBay right now bits and pieces started around $200 that's not the completed just the main plate and the rotor and it looks like a complete automatic is in the approximately $400 range. So just keep an eye out on eBay and one will show up sooner or later.
OK on the timegrapher the s/d was av 41 but has now stopped and so presume sticking. Interested to know what FU,FD,PU positions are though.
Quote
I had seen those pieces on Ebay but I think I shall wait for a complete unit. Is Ebay the only source though? Is there not a dedicated place to go other than that?
.....and Plato, Thanks for that
12 hours ago, Plato said:
That's the spirit!
😁......Am going in!
Quote
Sorry just remembered
Quote
Is this a supported action by members? sounds good and as mine is erratic to say the least it may be a starting point before starting the disassembling.
Sometimes I'll do something similar with hairspring rinse. Place a large drop right on the balance wheel hairspring to see if I can loosen things up. It's not a substitution for cleaning it's just sitting get the thing to run a little and see how it looks on the timing machine.
Some shops taken a step further and do something called pre-cleaning. This is where the hands and dial come off and The entire assembled movement is usually a separate cleaning machine. It's running a shorter cycle to the pre-cleaned the entire watch. Then when they disassemble or work on the watch they can better see the condition of the jewels whether they're cracked they can do their adjustments. Because classically and watch repair your repair the watch first then you clean it. But he oftentimes can't see what you need to see if the watches dirty. This is why they preclean then they do the repairs then they do a final cleaning And at that point time though disassemble everything for the cleaning.
But the catch to free cleaning is if you have stuff that has worn and you have metal shavings precleaning obliterates all that you may not see destruction.
Then I don't suppose we can have a picture of what yours looks like on the timing machine before you do any of this?
It wont replace clean or preclean but loosens or partially dissolves dried oil, just to free the oscilator, in case you got some lighter fluid  on hairspring just puff air on it to speed up evaporation. if you observe  no difference I start suspecting other possible faults.
I never thought of that.
Thank you john,
Regs
2 hours ago, JohnR725 said:
free cleaning
Dictation software is really nice as I talk words magically appear on the page it sets me free but? Sometimes the word isn't quite right it's supposed to be pre-cleaning.
Now more erratic than before.  2nd photo 3 mins later. Observations please
....and thanks for all the interest by the way-gives me a lot more confidence.
I have noticed in some pictures of the 645 that there is a what looks like a spring surrounding the balance regulator arm. Important ?
What it tells us is it needs to be serviced. If the amplitude is superlow everything gets magnified especially the beat error. This is why you don't worry about the beat error unless you're at like 200°. The running slow is an issue but we won't know until it's been better cleaned and better running as to whether it's going to be an issue or not.
If you want to have fun now and try an experiment put some lubrication on the escapement. It doesn't really matter what you use 9010 would work don't even have to use 9415 just put some oil on it and see what happens if the amplitude picks up. You can't really oil the escape wheel because there's an end stone.
But just for the fun of it you can see what happens. It's not a substitute for proper cleaning and lubrication though and more than likely a new mainspring if it's never been changed.
I have attached a picture of what you're talking about I assume? In order to have one of these there has to be a hole for the screw and another hole for the pin on the end of the arm to hold it all in place. As there's no way to mount it  you never had one. Strangely enough looking at my 635 I don't have one either. But earlier in the week we had a  I'm assuming so 645 I wasn't working on it and it had the holes but the micro regulator part was not there.
OK John. As suggested popped some 9010 on the escapement and not really much change. Took these as a complete picture for you. So what am I probably looking at?
Almost always with this fault it is the escapement that is at fault.  The behaviour of the hairspring is a good start and it needs to be observed in all positions. Does the hairspring stay flat is there bunching of the hairspring coils in different positions. Then there is end shake and side shake too much can really cause issues on from this is the cap jewels check for damage and cracks. Correct lubrication  of the jewels is also important.
The bottom line is it can be a very frustrating fault to find but the investigation process is just part of the never ending learning program of horology.
PS I know because I have been there many times. 😏
From those readings, desperately in need of a good clean and some fresh oil. Other than that, hard to say, but there is potential (clean traces in some positions). Will watch your progress with interest!
Checking things like end shake is why people servicing Rolex watches use pre-cleaning. As it's considerably easier to check all the clearances with a clean watch. But we don't have a service manual to know what they're supposed to be adjusted to so I wouldn't worry about that
Then oil on the escapement? It made no difference because the entire rest of the watch needs to be cleaned and properly serviced. It was an experiment to see what would happen.
Thinking about the hairspring what does the spacing of the regulator pins look like?
Then really anything else can't really occur until you get the watch cleaned and lubricated. Even though there is no specifications for early Rolex watches typically when you look at modern Rolex watches at 24 hours they would like to see 200° of amplitude. Because as I pointed out up above when the amplitude goes below 200 everything gets exaggerated Then trying to fix problems when you're having an amplitude problem isn't going to help anything at all probably make things considerably worse.
OK thanks everyone for all the feedback. Am going to clear the decks before starting this and wait for a quiet time.....watch this space! Have a good Christmas,
Cheers
Simon
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
