Help with a seiko KINETIC 5M22-7B40
hey everyone! im new here!
I need some help from you guys, im trying to rebuild my dads first watch. Its a seiko kinetic 5M22-7B40, obviously the movement is rusty like all 5M22-A i know... i have a new 5M65 moviment, wshich look like it will fit, but not sure. Anyway, did you guys know if it is possiblie to rebuild a rusty 5M22 using parts from a 5M65?
Or someone have a diferent ideia?
im in mission to rebuild this watch, so any help is apreciated!!!
thanks to everyone!!!
38 minutes ago, JOAOmaltez said:
I have a new 5M65 moviment, wshich look like it will fit, but not sure.
Just try it, as long it fits it will be good to go. Possibly one of our fellow members will provide you with the relevant technical sheet, these are more useful at the more advanced stage of taking apart movements and putting them back together in a better state.
5 hours ago, watchweasol said:
The first thing to do is to check out with the Dr Ranfft database the characteristics of both watches regarding exchaning and measure the dimentions of both movements.
Ranfft has about zero information when it comes to non-Swiss and non-mechanical calibers. But a lot of information is available online anyway, just search and read, again and again.
Thanks so much to everyone! so far, i found out that 5M65 has 4.5mm hight, being the 5M22 4.3mm...
I will maybe trying to build something out of this two!!
Its impressive how little information are about this watches and particular the 5M22-7B40.
I will continue to update you guys!
thanks again!
*if there is new ideas, pls share!
Best regards!
18 minutes ago, JOAOmaltez said:
Does anyone have a technical sheet for a 5M42 A?
Have you checked on the website (thewatchsite.com) that watchweasol indicate before? There is a topic dedicated to a large collection of service sheets.
In general, when it comes to watch documents and parts, if something is not found by a google search, it is not available at all.
  • 1 year later...
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
