Gearing Up My Tools Set
Affnan
Its looks like I'll be serious in doing watches.. firstly I work with tools all my life in the Aviation industry doing Avionics or B2 in the European area and we use high quality tools no compromise there. On the personal ground I do love doing Cars and Bikes and as I said before, age is cropping up and I am not in the prime as I once was. Watch making looks like a good alternative when I retired.. in few years.
So here I am doing watches... and from the few reply I got on my intro post.. many here are somehow in the same boat..
Only started to have interest on watches late last year and buying tools to do the simple job, since I am learning. The tools I have are mostly Chinese made.. and it does say "High Quality" .. well it doesn't cut it, especially the smaller end of the scale where they fail.. either sending screws flying or distorted tip of the screw drivers.
Decided to take the plunge and take a deep breathe and go for better quality tools... what I had in mind was A*F, Horotec and Bergeon .. Bergeon being last in the list due to the price scares me.. Visited a watch shop in Kuala Lumpur to check what tools they have and it look like I have to reach deeper since they do mostly Bergeon.. !!! :(
My first high quality tool to show and replacing the ones that I use ...
Bergeon Screwdriver Set No. 30081-S09
Replacing my "High Quality" Chinese set... :) on the right.
Being 53, its obvious my eye sight is no more 20-20 so I have to take care of what is left. I need a better loupe then I am using now.. those are the cheap dime a dozen on ebay.. so a Bergeon No 2611 No. 2 Loupe is added to the **BLEEP**nal.
As a start, these are the higher quality tools that I am getting to replace my current sets of tools. I do not want to over do it .. slowly but surely and like most people doing new stuff I am trying hard to avoid the "Gear Crazy" bug
Really interesting topic, i was aiming to change my cheap tools into a Bergeon tools.
So, where/how can i buy Bergeon tools with safety about the authenticity?
Check that screen
I'm a 99% sure, that isn't an original.
Do you follow any particular seller on Ebay?
@ Icarus,
Have you tried local suppliers near your place?...or even directly from UK or USA? We have a section here where you can find suppliers from all over, make sure you check them out for convenience!
@ Affnan,
Good move, Affnan, you will notice the difference and will enjoy your work more!
Cheers,
Bob
@ Icarus,
Yes, my father it's a watchmaker for almost 20 years and his dont care much about the tools quality as i, so we know all the sellers here in my region, they ALL sell only #$%@# stuffs from china.
I never bought Tools from Ebay, becose of this i asked, i'll try to search this section on fórum.
Thank you, Bob
To buy absolute genuine then I would avoid eBay use a recognised supplier. The oyster case opener for Rolex I purchased & it did not work it slipped under pressure. Purchased the Horotec case opener with the appropriate die & no problems.
@ Icarus,
@ Affnan,
Cheers,
Bob
Yes.. Bob.., it is so much easier as compared to my previous set... no slips and it is a very sure footer on the screw. It worth the hard earned cash that I paid for it.
@Icarus, those tool on ebay that you show tho the box is yellow, they will come with a Chinese names. I did purchase 1 or 2 of those as Clockboy said.. is very true, I experience the same. I had ordered one item from Cousinsuk and waiting for it, will see if it's ok I'll purchase more from them since I find their postage is very reasonable.
Affnan
    • Maybe it's just a coincidence, but note how the epilame-treated surface is illustrated in @Waggy's post. It looks like the oil is exposed to a binder (epilame!) so that it can't move sideways.
    • The epilame under the oil will also be removed  Unless the oil makes a barrier between the epilame and the escape teeth 😅 I think i need two strong coffees now 🤣
    • If we use the rub-off epilame method of pallet stones (run dry for a few minutes before applying the epilame) where will the oil go/be transported when it is pushed away from the impulse surface by the escape wheel teeth? Onto the epilame-treated sections of the pallet! Once the oil has been applied/transported to the epilame-treated sections of the pallet where will it then go? Nowhere as the oil will remain on the epilame. So, perhaps the run-dry method defeats its intended purpose leaving the pallet impulse surfaces dry!? If, on the other hand, we do not remove the epilame from the pallet stones where the escape wheel teeth come in contact with them I'd expect more oil to remain where we want it and need it. Yes, I agree, that is the question, and my gut feeling tells me that is exactly the case. Epilame was created to have an adhesive trait and the oleophobic property is just a side effect.
    • Might that be the viscous nature of oil resisting gravity H  ,  we have been comparing water and hydrophobic surfaces which are similar in principle but water is much less viscous than oil. I guess what we trying to discover is if epilame also has an adhesive trait as well as being oleophobic. Plus the oil dropet has very little mass for gravity to work on, like watching tiny water beads that can grip onto vertical glass until they are connected together to increase their mass then run down. Gravity isn't the only factor at play when oil is placed on pallet stones. The oil receives a lot of bashing that may push it out of position ? Thinking about it if the oil stays in position for 10 minutes enough time for the escape wheel to scrape off the epilame , then  a walled in lubrication has been achieved,  the epilame is no longer beneath the oil ( possibly mixed into the oil )
    • But it also makes it seem less susceptible to gravity. If you place a droplet of oil on an epilame-treated surface the droplet of oil will still stay in place even if you then flip the surface from a horizontal to a vertical position. That is, the oil droplet remains anchored, and that's the purpose of epilame. If it was just a matter of creating an oleophobic surface we could probably use other, less expensive, methods!? I don't know @Waggy but my gut feeling tells me you're spot on (pun intended!). I believe the oleophobic property is a side effect of epilame which is designed to keep the oil anchored.
