Vintage Matile Lower Jewel Loose
ken
Hello I'm new to fixing watches, so I post here first in hope of not making mistakes,
I have an older Matile poket watch. The balance is moving around but the pivots look ok (there long ones) but the lower jewel is floating around, it's running upside down, so I'm letting the spring run down, short of removing the dial and looking at why it's loose any suggestions what may have happened, I posted some photos and a short video on my face wall
Hi Ken, welcome to the forum!
Looks like the dial side jewel assembly has come adrift but I would not rule out a broken balance pinion as it is very unlikely for the balance jewels to come off, especially on an older pocket watch without shock absorber as the cap jewels are screwed in. On newer watches with shock absorber the spring can break and this will lead to the jewels moving.
Only way to check is to remove the dial.
BTW you can release the power from the mainspring by releasing the click and releasing the power gradually by means of the crown or a screwdriver on the ratch-wheel.
In fact you should do this even when the watch has run down as there may be residual power left in the spring.
Anil
Welcome to the forum Anilv. Pocket watch parts are not easy to source & most try to find another donor movement and swap parts to make one good one.
It,s a good idea to post your pics to your posts as we can then all have a good look to see whats wrong etc. Normally there is a member of this forum that will have the answer.
Welcome to the forum Ken, you will find this a friendly place where you can get good advice and the odd bit of leg pulling! That's good advice from Anil, and I too recommend you look very carefully with a loupe for a broken pinion.
Now for the leg pulling!
Clockboy I assume you meant to welcome Ken to the forum, or did you not welcome Anil last year? ;)
Sorry all another senior moment
How do they hold that jewel I place? Is it press fit? I see the cap jewel but don't see retaining clips, I don't want to start prying at it, I'm going to need better tweezers! My X-acto pair is showing its weekness
Hi Ken..
I'm having trouble understanding you..Lets backtrack a moment toen sure we're talking about the same thing.
1. The part you have removed from the watch is the balance cock with the balance wheel attached. The cap jewel is held in by the shiny chrome circle with two dots in in. These two dots are the **BLEEP** end of two screws. To access the head of the screws you need to remove the balance wheel first... In this particular watch the it is pinned in place, and its not really easy for a beginner to get it back together .once the balance wheel is off, remove the two screws and the whole thing falls apart pretty easily.
2. In the pics where the balance wheel is laying on the balance cock, next to the pivot you will usually see a small jewel sticking out. This is the roller jewel.
3. In your first message you mentioned the lower jewel was loose. I understood this to mean the bottom jewel which is the jewel in the main plate (behind the dial) where the other pivot fits.
Reading your last post, are you actually talking about the roller jewel as described in point 2 above? if so  then this is fixed in place with shellac. Shellac is heated and melted around  the jewel (in very minute amounts). Dont be tempted to use superglue etc.. it wont work.
Anil
3.
Hi Ken..
Anil
3.
Yes the jewles are not the same, I guess, it's the jewel in the bottom plate, Its not out completely but it's wobbling around the jewel hole, I just assumed they were held in the same. I see the dial is held in with half screws, nice I don't like the taper pins. The roller was out of align 1/4 turn, don't now how that was set. I did try to turn it with out removing the roller but it only moved a tiny bit so I decided to remove that taper pin when I seen the extra hair spring, this got me up and running. the pivots have ends. I have never seen long pivots like this. So I'm not sure if there supposed to be a bit longer or not. That lower jewel flopping around the hole is a strange prolem, with the spring pined in the position who knows what a poor life this old time piece had. I think the least I touch this the better.
I think I was wanting to remove the top cap jewel to try a tiny bit of synthetic clock oil I have, I think the doing ran down, the click is so tiny I don't even want to touch in. I just fee like my tools are over sized for this work. And still I want to enjoy a running watch from 1880
Here is another jem, I repaired this with some great tips from marks videos, it's a F. Rotig Harve (E. Howard?) I timed it the way he showed and its within seconds, wow what a masterpiece, for what I paid you can't even buy a Quartz movement. I love itimage_6.jpg
I tried to add a video of the watch running but I guess I'm new to posting and repairing
Edited by ken
Ok here is what I've got, I removed the hands and the dial, and I only see one screw on the bottom jewel cap wow I hope it's just loose ??
I really don't know what I'm doing,
so far so good though the spring is down. I want to take of the top plates and wax it like a car hood, I know that's wrong and with antiques if you clean of the tarnish you take all the value away. So I wait for all the great advice for chock workers in the know. I don't have money $$ for all the awesome tools, I do have a few, nice ones too. Like this K&D hand remover,
image_7.jpg I didn't need to spend $35 for it and the hands just came off this Matile with easy pressure. But I'll add to my watch hobby.
Hands were bent.
True, but it renders a Salvador Daly flavor to the vintage watch! :)  One thing I like about those watches are the cleanliness of the face design, the small seconds and the general elegance of the ensemble. As I've already commented in previous posts, they sport a superior workmanship that can not be compared/found in the factory made products of today. Just the good old times I guess!
Cheers,
Bob
It turns out the jewel retainer screw is stripped or the hole, I put some tape to hold it for now. Anyone on stripped tiny screws. I'll be looking for another screw but I don't want to glue it. It's ok you guy's jump right in here, I have plenty of time to do this right!
Hi Ken, you've done really well to get it serviced and keeping good time. :)
Regarding the stripped thread on the cap jewel retaining plate; I'm assuming it is the thread in the main plate that is stripped, and if so you should be able to rotate the cap a little and drill and tap another thread. This will mean using a micro drill and tap of the correct size. Not too difficult a job if you have the correct equipment.
If you don't want to go to the expense of purchasing a small precision pillar drill, you could drill the hole by carefully using one of these http://www.ebay.co.uk/itm/Archimedes-micro-mini-hand-drill-and-20-HSS-Titanium-coated-drill-bits-/361214643509?pt=LH_DefaultDomain_3&hash=item541a120d35 just make sure that you keep it vertical when drilling.
As for the tap, you could buy the likes of this http://www.ebay.co.uk/itm/NEW-Quality-Screw-Plate-with-14-Taps-Dies-Watchmakers-Jewellers-/200965782440?pt=LH_DefaultDomain_3&hash=item2eca7e7ba8 not the best, but probably good enough for what you require at the moment.
If you can find a screw that is one size bigger than the original, you will only require a matching tap to re-thread the original hole.
when drilling.
I did pickup a tool for tapping, not sure but seems a bit to large 1.0 to 1.7
    • Yes: that's it exactly, right down to the break in the spring!!
    • I've bought brands like Citizen, Seiko, Titoni, Tissot, Roamer. Strange thing is many of them were using ST96 movements. I'm not sure if the ST96 is original to that model or whether it was a replacement movement.  All the watches with nice looking dials were obviously refurbished, after-market dials. And all of them had over-polished watchcases. Some of them had non-original hairsprings, rejewelled pallet forks, watch crystals that don't fit and glued in with a generous amount of glue. One of them was totally not working because the pallet jewel was loose to the point that it almost fell off. But the sellers were very nice. The seller of the non-working watch gave me a complete refund. Some of them gave partial refunds. I would say don't by luxury watches on the internet, regardless of the country the seller is from. Don't believe the "serviced by master watchmaker" statement. Have realistic expectations. ( Do expect the occasional complete junk.) Do expect to do a complete overhaul and major repairs. Otherwise, watches from Mumbai are great. For clocks.... I'm not so sure.
    • In 2020,I picked up an Orient Mako II online. It ran at +15 seconds per day and after 3 years of resets more than weekly, it was time to crack the seal and take a shot at regulating it. Not having a timegrapher, I used a spreadsheet to track the time, referenced the Canadian NRC website, wore the watch between adjustments, and used the back end of some tweezers to lightly tap the regulator daily until it ran to within one second per day.   Two months later, it’s still running to within 1 second per day when measured over a week or longer, while daily variations are up to 9 seconds per day. For my purposes, its overall stability is surprisingly good. Is this method of adjustment “better” than adjusting to 5 positions using a timegrapher, since during the adjustment period the watch is already in the environment in which it’ll be used? Rob in Winnipeg
    • Nice file  Just got old pocket watch in and tools,  can I get it back together or should I give up.  we'll see  thanks for the info
    • @HectorLooi Yes, I would say that Mumbai has the highest liquidity in terms used watches. How was your experience with these used watches and what watch brands did you buy used? I have always found the vintage luxury watch segment in India a bit shady. Quite a few are genuine watches with genuine matching parts but just not from the same one.
