By Willem1961 · Posted
Dark blue dial with black backcase and rubber strap Grey dial black backcase -
That can easily be programmed around and already is in some instances Tom
By luiazazrambo · Posted
If you didn't know: https://youtu.be/iEkKwOWZS_E?si=CAGsEqvLdfKz7UWT -
Are you open to other things that would make your timepiece go faster. Does it have a bimetallic balance wheel for instance? Often times they get squeezed they're no longer round the arms get bent in that would speed you up. Also when you're looking at your balance we'll make sure you have even pairs of timing screws. It's amazing how fast you'll go if you're missing one of the timing screws so there have to be opposite pairs in other words if there's a screw on one side there should be a screw on the other side. If the hairspring is magnetized has oil on it or anything that causes it to be stuck together. Or for that matter it's touching anything. Also how was the balance wheel removed from the bridge oftentimes they're unpinned as do not do not have a stud and if that happens somebody will shorten their spring.
