  • 1 year later...
2 minutes ago, RichardHarris123 said:
Nit size?  Like the thing's people get in their hair?  Hehe.
Yeah, that threw me.  The size of the hole is the same as the stake: 4.7mm.  All of my "standard" stumps are 4mm, so this little thing is a **BLEEP**.  One would think that my Dad (the source of this thing) would have had some stumps to fit it, but I have not seen anything that fits the bill, but I may have overlooked them.
1 minute ago, RichardHarris123 said:
Could you make stumps ?
Yes, but it would be a lot of work.  I think they have to be hardened--still trying to get my head around metallurgy.
But...at the end of the day, I don't need another staking tool.  I think I have five now.  What I do want to know is how my Dad used the tool.
On 5/21/2021 at 8:54 PM, LittleWatchShop said:
I am gonna search around the watch bench and see if I can find these additional parts.
I was thinking that looks like the one that I have. Not sure where mine is right now and no there were no little bits and pieces with it. But my guess is that a long time ago before we ever had ours the bits and pieces migrated to a standard staking  Set.
_____
As an aside...Ebay is a great place to do research when you are trying to suss out the purpose of a tool are dig up information on a watch.  Odd to use it that way, but it works.
I actually have two of them!!  One from my Dad and the other was in a watch bench I bought (I think that is where it came from...stuff just shows up around here!)
Maybe.
13 minutes ago, LittleWatchShop said:
_____
It's disappeared from my house, other side of the worm hole.
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
