Vexing five-sided screw (CustomTime)
Ok, so I finally hit my limit on this one and had put it in a box out of sight and out of mind for a few weeks. It’s time to ask for help!
I purchased a CustomTime jump hour movement on eBay a while back, “for funsies,” but have been unable to open it due to a set of five-sided screws holding the case to the main plate. I have bought screwdriver sets online and tried everything I can think of to open them, but everything is too big or too small.
Any suggestions? Does anyone know what type of screw these are and what the correct way is to open this movement?
Many thanks!
Dave
It seems a really Strange way to do things? Not that odd things don't occur every day in watch repair. Almost looks like inexpensive watches when they pressed something together it's a form of a rivet. But it may be a screw it just doesn't look right.
Find a piece of steel and just file the shape. I don't think you're going to find custom screwdrivers the right shape.
Just now, Marc said:
I think that those look more like pressed rivets than screws.
I definitely agree with this
look at where the movement fits into the case in other words where is the edge of the case versus the edge of the movement and gently pry it's probably just stuck in the case back. There'd be no reason to have all those screws which I don't think are screws holding the watch to the case back
Always best to identify the movement you're dealing with first. Invariably this information is stamped under the balance wheel.
This is probably a Baumgartner so I'd expect you to see a 'G' with smaller 'BF' inside. But what's the model? Once you find this then some better info will become apparent.
Let me assume it's an 866 for now. In which case there's a helpful breakdown on this very forum at https://www.watchrepairtalk.com/topic/14174-baumgartner-bfg-866/
And those five sided screws? Nope ... as you'll see they're just the top of the legs the plate locates onto.
You’re absolutely right! BF 866!
Good call. ?
17 hours ago, WatchMaker said:
Hi @DavidADav- glad that was helpful. You did the right thing by not forcing and asking first. Good luck getting your 'digital' watch going!
Thank you! It is now serviced and running like a champ. I cleaned up the case as well, and now just need to outfit it with a new strap. I’m thinking of throwing on a 70s style cuff, since it’s a unique piece.
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
    • Hi   Find attached parts/repair notes for the JLC 911,  might be useful. JLC_JLC 910, 911.pdf JLC_JLC 910, 911 Repair Notes.pdf
