Hello from Kentucky
jtking96
Hello! I'm a mechanical engineer from Kentucky, and I've had an interest in mechanical watches for a long time because of the detail and craftsmanship involved in them, though I only own and wear one simple watch, a Seiko 5 sports watch. Recently, I got a suggestion for a Wristwatch Revival video on YouTube. After watching several of his videos, I decided I would get some simple tools and try my hand at servicing a watch, and I also made my way here since he speaks highly of Mark in many of his videos. I picked up a working 1953 Bulova from eBay for $24 shipped, and got the movement (picture below) stripped down and ready for cleaning. Hopefully I can get it back together okay!
I'm looking forward to learning more about this hobby!
 Although diagram&datasheel is likely to be available on this caliber, taking many pictures as you tear the movement is a good practice to make a habit of, lucky finding out what parts goes where is easy on this one.
Someone must have cleaned it in shellac unfriendly cleaning solution in cleaning machine, since I see no trace of shallac on pallet jewels.
Welocme to the forum.
Regs
Joe
I took a picture of every screw I removed next to the hole it came out of, plus some more on top of that! I considered taking a video even, but that felt like it was going to be too much setup.
The pivot side of the pallet fork is pictured below, looks like there is shellac on that side?
You’ll do great. Just be patient. If (when) you start feeling stressed/frustrated, walk away for a bit. That’s the first thing my mentor taught me. Well, that’s the second thing. The first thing was when he pointed at the hairspring with his tweezers and said “see that? That ain’t no F’ing slinky!”
    • Yes: that's it exactly, right down to the break in the spring!!
    • I've bought brands like Citizen, Seiko, Titoni, Tissot, Roamer. Strange thing is many of them were using ST96 movements. I'm not sure if the ST96 is original to that model or whether it was a replacement movement.  All the watches with nice looking dials were obviously refurbished, after-market dials. And all of them had over-polished watchcases. Some of them had non-original hairsprings, rejewelled pallet forks, watch crystals that don't fit and glued in with a generous amount of glue. One of them was totally not working because the pallet jewel was loose to the point that it almost fell off. But the sellers were very nice. The seller of the non-working watch gave me a complete refund. Some of them gave partial refunds. I would say don't by luxury watches on the internet, regardless of the country the seller is from. Don't believe the "serviced by master watchmaker" statement. Have realistic expectations. ( Do expect the occasional complete junk.) Do expect to do a complete overhaul and major repairs. Otherwise, watches from Mumbai are great. For clocks.... I'm not so sure.
    • In 2020,I picked up an Orient Mako II online. It ran at +15 seconds per day and after 3 years of resets more than weekly, it was time to crack the seal and take a shot at regulating it. Not having a timegrapher, I used a spreadsheet to track the time, referenced the Canadian NRC website, wore the watch between adjustments, and used the back end of some tweezers to lightly tap the regulator daily until it ran to within one second per day.   Two months later, it’s still running to within 1 second per day when measured over a week or longer, while daily variations are up to 9 seconds per day. For my purposes, its overall stability is surprisingly good. Is this method of adjustment “better” than adjusting to 5 positions using a timegrapher, since during the adjustment period the watch is already in the environment in which it’ll be used? Rob in Winnipeg
    • Nice file  Just got old pocket watch in and tools,  can I get it back together or should I give up.  we'll see  thanks for the info
    • @HectorLooi Yes, I would say that Mumbai has the highest liquidity in terms used watches. How was your experience with these used watches and what watch brands did you buy used? I have always found the vintage luxury watch segment in India a bit shady. Quite a few are genuine watches with genuine matching parts but just not from the same one.
