I like the well-known brass movement holder for doing work, but when I have a movement in the "waiting for parts" mode, it is nice to have it sitting in a nice stable holder.  So, I decided to print this movement holder.
Print time was 20 minutes.  Probably took me about that long to design it.  Now that I have one complete, I can tweak it for other movement sizes with only a few minutes of effort.
FYI, this is a Landeron 51 chrono.  I cleaned it and it is running fine, but I need hands and a decision about the dial.  I have a dial, but it is in really poor shape.  I see hands and dials on Ebay, so I just have to decide which one to commit.
This type of holder should be so sligly undersized so to grab thanks to a slit in the diameter. And when is for a chrono mov.t all the difference is made by having pushers.
Will you publish it on Thingiverse or perhaps just attach files here?
I am attaching the Freecad file.  I use Freecad which is open-source software that is heavily supported and it is FREE.  Been using it for three years and love it.
STL file also attached, but it is not as useful because it is much harder to edit.
When I get some time, I will parameterize this for easier mods.
movement_holder 2.FCStd movement holder.stl
Edited by LittleWatchShop
  • 3 months later...
Here is an update on the movement holder.  When I store an unfinished movement in the popular domed parts carrier, it tends to flop around if I try to place it in the center.  The solution was to put a base on the holder that sits nicely in the center partition.
  • 1 year later...
I made these as generic movement holders, they are 2 for 1, just flip them over to get a 0.5mm larger or smaller. just let me know and I can send you the .stl file for them.
For someone completely new to 3D printers, do you have any suggestions on what to purchase? My main interest is little horology tools like these movement holders, mainspring winders, and such. For what it's worth, I'm running Apple computers at home.
Thanks!
My son owns the printer, I just feed him the drawings and he works his magic. I'll see if I can get any advice from him and pass it along.
Thanks!
I use a Lulzbot Mini which I bought about five years ago.  Have been very happy with it. Print ALL the time.  It is a little pricey.  I suggest you consider a Prusa.  The product line is well received and is very economical.
35 minutes ago, moodesu said:
Good work on the holders, I am printing the 2 for 1 now.
Hope you like them 🙂
Anyone have any 3D stuff they have made that would be good to share, I asked on another post about movement holder rings for Seiko (not dial spacers) but nobody has responded
Edited by Waggy
Let me know how they turned out 🙂
Mr filament broke halfway through... Do you have the separate files rather than 4 in 1 file?
Sorry I don't have a separate file for each holder, I sketched them out and my son drafted them for his printer. I have now forced myself to learn the software he uses, but these were done before that. I'll see if I can get him to split them out.
  • 8 months later...
I have a 3D printer on the way and am playing around learning FreeCAD. This looks similar to what I will be trying for my first project (movement holder that fits in the hand setting tool). Could you post the FreeCAD file? I'd like to see if I can adapt it to what I am trying to do.
By the way, your movement holder has that 'ledge' that is below the top of the holder which the movement rests on when in the holder. When you designed how thick the ledge is and how far down from the top it is, did you get those numbers from measurements you did on the movement or is there some other way you decided on those numbers?
Edited by GuyMontag
WRT does not support FreeCAD file types.  PM me and I will attach to my reponse (if it lets me), or we will go offline via email.
My design was a simple hack more or less.  All measurements except for the width of the movement were SWAGs.  You will see in the FC file, I created a spreadsheet to parameterize the elements.  The extra piece on the bottom to fit the movement holder was also an "addon" hack using the Part workbench.  It too is a hack...lol.  When exporting to stl, you have to select two sets of elements.  If I were to do it over again, I would assemble the whole thing using Part Design workbench.
Thanks, I'll send you a PM.
Wow, great minds think alike, I use freeCAD and also have a 3D printer being delivered by Santa 🎅, I currently have to bribe my son to use his. I was was thinking on Friday afternoon that it may be cool to try some parametric modelling in freeCAD and sketched out a parametric movement holder. My idea was to measure the movement outer diameter and then let freeCAD spit out the complete design.
Here is what I sketched in my lunch hour (including a doodle I did whilst on a very boring conference call) on Friday:
I also plan to put a fillet (0.25?) on some of the outer 'corners' mainly for aesthetics, and one on the entry to the seat to make it easier to get the movement in, but didn't get time to add them to my sketch, blue circles above.
Also l1  is the cutout for the stem/crown, was thinking of making it U shaped rather than square, but would model it as a square and simply fillet the corners to make it a U shape.
Just in case you can't make out my handwriting:
d1 = variable (the movement holder OD and the only input you need to make)
d2 = d1 + 10 mm
d3 = d1 - 5 mm
d4 = d2 x 1.5
r1 = h2
l1 = 10mm (with 2mm filets{?} to make it a U shape)
h1 = 5mm
h2 = 30mm
h3 = 5mm (will only need this outer dimension also to be h3 if I decide to keep the 'shoulders' at the top of the model, thinking I may just skip the outer shoulders and have the top and bottom linked by an ark without the shoulders... I will need to think about this....any ideas??? My initial thinking is that the shoulders may flex a little as you push the movement in and grip the movement better, but not sure how realistic this idea is?) - see version 1 and version 2 below.
Once I get to grips with it, I'll post the freeCAD design on thingiverse and you can also PM me for it from here 🙂
Version 1 and version 2 of the top of the movement holder
Edited by Waggy
Typos
Think I did it.....
Below  is my parametric movement holder (size 30mm movement)
Below is size 10 mm movement (minimum size before model breaks):
Below is size 70 mm movement (maximum size before model breaks):
And here is the Parameters table - only need to change the red text cell at the top:
PM me if you want the link to download 🙂
This is in FreeCAD not sure if it will play nice if exporting in other formats, but I'll give it a go if you let me know what you need.
I think I managed to create a link you can download the freeCAD file:
LINK HERE
Thingiverse link:
LINK HERE
Edited by Waggy
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
