Please explain these "oiling" symbols from watch datasheet
15 minutes ago, LittleWatchShop said:
I could guess...but the experts here know.
Your drawing house a interesting problem to symbols in one location? The ghost the image probably means I ghost the quantity of oil minimalistic.
I never really paid attention as to whether they had exact meaning are not as usually anytime M assemble in the documentation it will tell you what oil you should be using. For the fun of it I went through a variety of eta documents and snipped out the lubrication symbol meanings. It does look like there is a pattern here.
Then it occurred to me that I never paid attention to it we really need a lubrication guide This one from Omega. Sure enough they have symbols lots of symbols and they tell you what they mean sort of. Notice it isn't an exact science and no matter what it would never be an exact science because lubrication changes with time. So if you look at the Omega document and all the images they came out of a variety of eta documents you kinda get a pattern. Light oil is one symbol a little bit heavier is another but it still doesn't look like an exact science to me you really need the full document that you're looking at where it tells you what they think it is and then we translated in something modern.
Omega 8645_WI_40_rules for lubrication cousins uk.pdf
This is helpful!!
In Seiko guides they'll use these to indicate how much oil.  Wedge with one ball is normal, wedge without ball is minimal, and with two balls is generous.  Hollow, solid, or angular will indicate different lubricants.
The symbols are not standardised, so without the key for the document in question, you are guessing. The lubrication plan is still useful though. It prompts you to put "something" in a particular spot (and nothing anywhere else). You can make an educated guess about what that "something" is, and how much to apply. You might decide to deviate from the exact recommendations of the plan in any case, depending on how up to date it is, and what you have in stock.
As Seiko's been mentioned here I snipped out a few more images. Something that Rolex has and two separate ones from Seiko plus Seiko's OEM branch time module.
Not entirely correct? The actual symbols do seem to follow a standard in other words these are the symbols of lubrication. But beyond that any sort of meaning of what each symbol represents to each manufacturer at any given time appears to not resemble a standard at all. So basically you need to have the chart that goes with the symbol that you're looking at to understand what it is they think is going in that location.
I like the "normal" vs "sufficient" indication.  Is sufficient more than normal or less?  Should points not marked sufficient have insufficient oil?
Perhaps more detail could be added, with different arrows for "typical", "standard" and "correct" oil amounts.
Was reading to replies here this reminded me of something? The time factor of what's normal versus what is not probably doesn't have any effect? If you look at current lubrication practices versus past practices interesting things happen. Like currently if you look at a pivot sticking out of the jewel and you can see the top of the pivot that's the maximum out of oil if your oil goes over the top that's too much. If you can't see the oil that's too little and somewhere in between is typical. But if you look at historical data or went to school in the late 70s that would be totally unacceptable. Acceptable was if you could not see the oil that had been applied. Super minimalistic was the normal which is now considered not enough. But you I think any of those specialized symbols for minimalistic are parts that would still require minimalistic.
I suspect what's happened is now that the Swiss have slowly terminated a lot of people repairing watches because we were not doing it properly and there are actually looking at their watches that have been in the field they discovered that super minimalistic just didn't cut it so now they require more lubrication.
Then when you're looking at symbols there is that other strange symbol? Wasn't always in the ETA documentation. It almost never see it in the past it was referenced in the manufacturing information sheet set watchmakers typically don't look at. You would see the reference to epilame On the balance staff the escape wheel the pallet stones. Just not in the tech sheet where the watchmaker needed it.
Or companies like Omega had separate documentation even in the 50s they talked about epilame For basically almost everything in the watch conveniently never mentioned it all on the normal tech sheets.
The unfortunate mysteries of lubrication where we never quite get the whole picture. But they are getting a little better about it at least is now mentioned in some of the tech sheets.
    • The fact that the seconds runner starts running smoothly when you engage the chrono seconds makes me think the clutch is out of adjustment. That's a guess because I can't seem to find out too much about the chronograph module Breitling used on this model. On other Navitimers they used the Valjoux 7750 which had the running seconds on the left where the hand was mounted on an extended pivot on the fourth wheel. It looks to me that whatever pinion is driving that wheel is skipping teeth. Given that Breitling (et al) is not forthcoming with manuals or parts, I would send it back and ask for expedited service. They should be sufficiently embarrassed to do that for you at least.
    • Looks like someone forced in a screw that was bigger than the hole.  You would probably need to drill it out with a tungsten carbide rod sharpened at the tip to look like a spade drill. I'll see if I can find a video on how to make one. Start with a 0.5mm rod, then work your way up in 0.1mm increments until the walls of the hole weaken the screw enough to break it up.  This is a very time consuming, slow process. You'll need to centre the hole properly and not deviate. WD40 helps. The other option is to abandon the hole and use a dial dot. As much as I hate dial dots, this might be the safest option for a beginner.  Ok, found it.
    • For those who are, curious I broke out the macro lens and took a few shots.  I'm attaching four of them: Image 1 is from the watchmaker's side and generally shows the problem area. Image 2 is a detail view of the offending dial foot hole (called out with the green circle), the tip of the offending screw (orange arrow) and the blue line indicates the approximate position of what's left of the head of the screw (determined by using an oiler as a feeler gauge to transfer that measurement to the visible portion of the plate.) Image 3 is looking down the screw hole you can see the head of the broken screw at the bottom. Image 4 is the same, but with less contrast to give a better appreciation of the condition of that end of the screw. I can almost convince myself that I can see the remains of the screw slot in the head, but I have to use alot of imagination in that exercise. Heard and understood.  There does appear to be a steel locating pin that can be seen in the lower, right center of Image 1 (right "above" the oval shaped slot that is to the left of where the pinion/clutch parts of the keyless works nestle into the plate.)  As I don't see a way to remove that I'd have to keep it out of the solution and have even contemplated dropping a little paraffin on it to give it a "rain coat" of sorts.  As I missed that before I did the closeup photos, I feel that I'm going to be looking at this plate in much greater detail to see if there anything else I might have missed. The screw assortments seem like a good acquisition.  The eBay seller who has the donor movements I was looking at never replied so I may just take a chance and get one of those as well a screw assortment.  They do seem like they'd be handy.  I have to confess that the idea of fabricating the needed screws appears to some deep part of my soul, I also have to confess that I do not yet have either the equipment, or the skill to use it.  Perhaps one day, but that day has not arrived (and I have alot of pricey bits and bobs that I will likely need to get along the way.) I thought about this, but the dial foot screw doesn't seem to be wide enough to get the thing out if I could advance it into the hole.  I suppose that I could try and take it out in pieces (advance it as far as it will go, get in there with some sort of saw, take a piece off, walk it forward again, take another piece, etc) but that seems like alot of risk to the main plate. I need to examine the other screw to ensure it doesn't have a shoulder or something that would prevent me from doing something like that.  However, all that said, I've been unable to get the thing to move at all. In general, this whole piece feels like someone had it before me, did a bad job of working on it and ultimately just bunged it all back together in a haphazard way and passed it on to be someone else's problem.
