Hamilton 683 malfunctioning
This Hamilton electronic equipped with 683 is not working . I placed a new battery and the balance wheel started moving after a manila push but second hand is not moving. If I look closely it's rocking back and forth but not moving. Any suggestions ?
It could be a warned battery if the balance wheel is kicking and the second hand moves back & forth -( a typical sign of low battery power).  Even new quartz watches some tell tale sign when battery is low the second hand kicks back & forth as a signal for battery change.  The gear train needs lubrication.
Edited by Elton
Do you know when it was last serviced? Electric watches, quartz watches and mechanical watches all require from time to time servicing. Cleaning replacing of lubricant with fresh lubricant otherwise when the old lubrication goes bad your watch can stop including electric and quartz watches.  Your movement appears to be a ESA 9154 Although it could be a 9150 you'll have to get the numbers off the plate they're not visible well enough to see in your photographs. To give you a clue what you're looking for them attaching an image of where the numbers appear to be.
Then a link that talks about transistorized balance wheel watches. A limited information parts list of the 9154 as it looks like they didn't scan the entire service manual? In case it is a 9150 I think I have a better service information. But oh wait and see what the number is off the plate
https://electric-watches.co.uk/movement-types/transistorised/
3540_ETA 9154.pdf
My lucky trick worked , I added a couple of drops of lighter fluid and it started working. Thanks everyone for all the support , I was nervous to open this one it's so complicated and I am still not good at opening movement
    • This is not rare at all, the dial code and case code don't usually match.
    • Good question!! Anyone know of a substitute movement??!! 🤔🙏
    • Interesting issue that I just noticed: this Seiko 5actus Watch from 1977 has a calibre listing on the dial of 7019-8030R but on the case back it says 7019-8010!! Like a mis-printed coin, is this watch therefore worth a lot of money for its rarity?? 🤪😲🤔🤪
    • I wish that was the case. The Aegler movements used in the early days by Wilsdorf & Davis (for brands like Rolex and Rolco) came in several sizes and without designated calibre numbers that survive.  They become a bit easier to identify during the 1920s. Below is an Aegler-Rebberg, 25.74mm in diameter. It’s from a woman’s Rolex wristwatch. Stamped Rebberg and 500 on the dial plate (but it isn’t a Rebberg 500, it’s the wrong size).  I’d be interested if anyone can identify the movement.  It is based off the Aegler Nr.1, circa 1903, but they based many many calibres of different sizes on it. The closest I have to a positive ID is the  ‘Rolex Nr.50’ circa 1917, but no dial side images or movement sizes are available in the references. There are identical looking movements in many sizes.  The 25.74mm of this movement is a particularly strange size for the era, it equates to 11.41 lignes.      Best Regards, Mark
    • It looks like this movement comes with a number of different shock settings. Emmywatch shows that it comes in versions with no shock settings, 'Incabloc', 'shock resist', and 'Supershock'. Perhaps the different settings position the impulse jewel/roller table in a non-ideal position relative to the pallet fork/guard pin. Are you able to check under high magnification if the pallet fork and roller table are able to operate without any interference? Just for fun I took a look and I have one FHF 70 in my collection, a West End Secundus with a non-shock protected FHF70. I had a note with the watch that said, "Movement is stamped 'FHF 70', but the FHF70 looks to have sub-seconds instead of center seconds movement (??)" but that a google search turned up both types for this movement. EDIT: I just took a look in my parts drawer and I have a few of these movements, both in center seconds and sweep seconds, but they all are non-shock protected.
