It was supposed to be a simple job. Just replace the battery...
But then I noticed there was a speck of dust under the crystal... So I took out the movement to clean inside the crystal.
Then I noticed the minute hand wasn't centred on the hour... So I removed the hands to realign them.
Then the minute hand stops moving... I took off the dial and discovered that the cannon pinion popped off when I lifted off the hands. ?
Now I will have to do a full disassembly to fix it. ?
I have to stop being so OCD.
Friction pinion all fixed up and reassembled.
On further thinking, is this a design weakness? If the minute hand is fitted too tightly,the chance of the pinion separating from the wheel again is very high.
Or is there a safer method of taking off the hands?
Or. . . next time just replace the battery and walk away LOL
I think we have all slipped down that rabbit hole many times. Glad you got it sorted.
IMO when such things happen, I look at it as an opportunity to learn more about the watch; as you have done. Most fo us have an extra watch around to wear while something is in process.
I know that rabbit hole too.
The last tiny little Elgin grade #320 I worked on just a week ago *only* needed a NOS mainspring installed.  That's all.
But then I got to thinking the beat could be a tiny bit better.  Had the balance out to tweak it a bit.  It went back in perfectly fine on the first try.  And again on the second try, and I was getting the beat close to perfect.  Then the third time...@#&^%&^@#$!!!!...that miniscule roller jewel would not go into the stupid stinking fork for any amount of love or money!  It was always one side or the other!  I spent the rest of the day sweating bullets with that tiny little thing, trying not to harm it in any way.  It finally went in, and I grabbed a shot of scotch afterward.  The watch ran supremely well afterward, but oh Lawdy it made me earn my bread and cheese.
    • Yes, the steel (and iron) solders well, but good flux is needed. This will usually mean acid type of flux, and after soldering, the part must be well washed from the flux, which is usually done with base solutions that will neutralize the acid remains. Actually, I don't know the current state of the wheel, so I am not able to give correct advice. But yes, if needed, new pinion can be cut. No matter what material the cutting wheel is, it is needed to start with soft steel (O1 is OK). After cutting the leaves of the pinion, the work must be hardened and tempered and only then the rest of the work to be done.
    • I doubt that I know enough at this stage of my journey to impart anything useful. I have the Laurel here, with (finally) the back off.  I also looked on Yahoo Auctions, there is a seller at the moment with what they've listed as a Seiko Marvel balance staff, but I don't know if it's the right part for your watch. It seems you need the whole balance anyway, and I'm not seeing any of those for sale. There is a very trashed looking Marvel from another seller that might suit as a donor unit, but no photos even with the back off, and the crystal is missing. It doesn't look promising: the dial is severely corroded, so useful internal parts might not be salvageable.  https://auctions.yahoo.co.jp/jp/auction/w1112646076 https://auctions.yahoo.co.jp/jp/auction/o1185016360
    • You've been to Aladdin's cave I see! 👍
    • So not a hack then, but rather an upgrade to modern space-age shock protection! 🤣
    • I was able to find a little bit about this watch though a google image search; BENRUS H010 TECHNIQUARTZ 1972 1st US made Quartz made by Benrus. Using a custom E-block with the step Motor, a power switch and a Moto Chip driven by MotoQ at 32KHz on modified mechanical movement.   Well I swapped out the quartz. Still no joy. This looks to have a capacitor, it that the same as a coil. How on earth do I go about finding a replacement?
