Purchasing Oils In The Us
BlakeL
I'm looking ahead at Time Zone Level 2 course and the oils needed.   It looks like if I get only the ones required then it's 140.99 shipped from Ofrei.  Is there anywhere else people are getting oils from cheaper?  Esslinger does not have a wide selection and some of them are more expensive.
Edited by BlakeL
I know what you mean Blake, I had to bite the bullet! On the other hand, they will last forever since you only use one drop combined for the whole watch...and sometimes that is too much oiling! Just be careful they don't get contaminated by cleaning the oiler every time you dip it.
I feel your pain,  I just dropped $160+ for oils.
You get them and you are like..."$40 for this??"
Then you realize that you could probably lubricate about a million pallet stones with this and it doesn't seem quite as bad.  Investment for the future I suppose.
I'm very confused by the basic/optional recommendations for oil on the TimeZone course site.  They don't seem to match what is recommended on the ETA Technical Sheets I found on Cousins.  I would like to get a basic set that would work for both of these movements. Any Recommendations?
Recommended for TimeZone Level 2 Course:
  • Moebius Syntalube 9010
  • Moebius 8141
  • Moebius D-5
  • Glissalube 20
  • PML grease
  • Moebius Syntalube 9020 (replaces 8141 on some train wheels, but 8141 still required)
  • Moebius 9415 (replaces 9010 on pallets, but 9010 still required
Recommended Oils by Tech Sheets:
ETA 2836-2
Fine Oil: 9030
Thick Oil or Grease: Moebius D5
Grease: Jismaa 124
Special Oil for Pallet Stones: Moebius 941
Unitas 6498:
Thick oil or Grease: Moebius D5
Fine Oil: Moebius 9010
Grease: Moebius 9501
Special Oil for Pallet Stones: Moebius 941 or 9415
Oh Blake, do I know what you mean mate!!
My "Christmas Project" 7750 walkthrough is still on hold due to the expense of all the lubricants I needed to purchase.  I didn't realize just how much it would cost, and it broke the budget for getting the movement holder ... which I need before I can start, and am still saving for at the moment :unsure:
...well at least once you've got them, it's reassuring to know they will last you a long time.
The 2836-2 arrived yesterday and it seems to be in great cosmetic shape.  I tried winding with the rotor but it didn't seem to start so will have to diagnose after disassembly.  It is missing the day wheel and whatever retainer holds that in place as well as the stem so I'll have to order those at some point. As far as the oils, I need to also rewatch Marks 2824 videos to see what all he uses as well.  I honestly just want to get the basics needed to do a full service on these two movements to start out with and then expand once I get more watches that might need different oils.
Hi Blake,
If in a "hurry", just for the class and to practice your oiling technique, you don't need to go with moebius at all. There are cheaper oils (some as good as moebius) you can use. Check out the oil section (or do a search in the forum). I remember there was an viscosity equivalence posted. Based on that, you can practice with those. I bet you won't spend more than 50 bucks for a full kit. Just remember that in the end you might want to bite the bullet though. Check esslinger for the silicone oils (10, 50 & 100) and the novodiac one...also the Indian silicon grease they sell...just to name a few. Remember this is not optimal!
Worst case scenario, well, nothing a good cleaning can't fix...and with the price of McDonnals, you spend that money easily in one breakfast for the family! :)
Cheers,
Bob
Thought I would share my cheat sheet for lubrication.  I plan to add a new tab to this for Chronograph parts as well as sections for date complications.
I put this together from Mark's videos.  If anyone sees something glaringly wrong, please let me know and I will fix it.
https://drive.google.com/open?id=1LiO9xEzvBK6C5kfLSarTTbtFMdQmeSaz1ozCHv4RDZg&authuser=0
That's a good start icius. I'll use it and add equivalents and eventually put it here for opinions. That will include cheap substitutions for those that just want to go through the techniques and experimenting.
Cheers,
Bob
Good deal guys.  This is exactly what I was planning on doing with Marks 2824 videos to see what he uses vs the recommendations from TimeZone School and the Technical Sheets. Bob, I'll look forward to your additions for budget options.  I'm still waiting on a few eBay items to sell before I pull the trigger on more watch items.
Edited by BlakeL
I'm
I'm just starting out (hobby) so to me your spreadsheet is a gold mine!  Thank you very much for putting this together and sharing.
    • Yes, I was referring to the (jewelled) gear train with HP (most of the time, I use 1300, but when Rolex says 1000, I'll use 1000).
    • did I miss the update of the message of something changing?
    • I suppose it would depend upon what your lubricating with those? for instance what does the manufacturer say about those lubricants? I have a PDF from the manufacture and a rather peculiar statement found on the bottom of the chart. my suspicion is the reason the recommending would be without epilam the HP oils like the spread except when they're in Ruby jewel's with steel pivots. tableEN lubrication 2020.pdf
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
