Hi all,
I found your forum when looking to buy an SKX looking at timing and regulation issues I might be letting myself in for and was amazed at how helpful you were. Now my SKX 7S26 has developed it's own fault and thought it was time to stop lurking and ask for some help.
I'm basically an amateur everything based in the UK who likes a value watch but doesn't mind tinkering, probably to my own detriment. I was expecting my journey with automatics would mean learning to regulate but up until now they all run within tolerances.
Andrew
    • Yes, the steel (and iron) solders well, but good flux is needed. This will usually mean acid type of flux, and after soldering, the part must be well washed from the flux, which is usually done with base solutions that will neutralize the acid remains. Actually, I don't know the current state of the wheel, so I am not able to give correct advice. But yes, if needed, new pinion can be cut. No matter what material the cutting wheel is, it is needed to start with soft steel (O1 is OK). After cutting the leaves of the pinion, the work must be hardened and tempered and only then the rest of the work to be done.
    • I doubt that I know enough at this stage of my journey to impart anything useful. I have the Laurel here, with (finally) the back off.  I also looked on Yahoo Auctions, there is a seller at the moment with what they've listed as a Seiko Marvel balance staff, but I don't know if it's the right part for your watch. It seems you need the whole balance anyway, and I'm not seeing any of those for sale. There is a very trashed looking Marvel from another seller that might suit as a donor unit, but no photos even with the back off, and the crystal is missing. It doesn't look promising: the dial is severely corroded, so useful internal parts might not be salvageable.  https://auctions.yahoo.co.jp/jp/auction/w1112646076 https://auctions.yahoo.co.jp/jp/auction/o1185016360
    • You've been to Aladdin's cave I see! 👍
    • So not a hack then, but rather an upgrade to modern space-age shock protection! 🤣
    • I was able to find a little bit about this watch though a google image search; BENRUS H010 TECHNIQUARTZ 1972 1st US made Quartz made by Benrus. Using a custom E-block with the step Motor, a power switch and a Moto Chip driven by MotoQ at 32KHz on modified mechanical movement.   Well I swapped out the quartz. Still no joy. This looks to have a capacitor, it that the same as a coil. How on earth do I go about finding a replacement?
