omega 30T2
gary17
hey
I needed a center wheel for this omega. Checked with cousins and it says center wheel and cannon pinion and gives a height. It then says obsolete. so took number and ordered part from ebay and its arrived .1 problem the center wheel and the cannon pinion are as one. I can not turn the cannon pinion  or the center wheel seperately . Now because the center wheel and pinion will not part it will not go through the center hole.
Anyone had this problem before or as usual is it just me.
cheers
gary
Obviously the canon pinion And center wheel should be able to rotate..  Somebody probably pop them together dry  and  their locked in place.  Try some penetrating oil and see if that will loosen things up so you can pull the canon pinion off carefully..  Then usually it takes a while with penetrating oil to soak EN so given a while  it's not usually instantaneous..
What was the part number?
Stuff like this doesn't always make sense? Sometimes there sized together but if that's true you should Not be able to  purchase either one separate. Sometimes there's been upgrades and modifications you see that in Omega documentation where they recommend changing components.
30 minutes ago, gary17 said:
hey
cheers
gary
There is no problem at all. Do not try to rotate the cannon pinion or pull it.
Think of this scenario as "Staff Roller Removal". Support the Cannon Pinion from below and with one strike of the hammer and sub-punch force the Main Wheel Pivot out of the Cannon Pinion.
This literally takes just a few seconds.
Edited by Poljot
It's a great plan except? If you look at the Cannon Pinion Way up above feel notice that it's shiny on top? This is a sealed canon pinion egg as a really nice look on the dial when hands go on and it's a nice shiny center. There is no way unless you drill a hole to put anything in.
46 minutes ago, gary17 said:
yer i cannot get a sheet of parts anywere. used omega 260.     30 t2 became 260 in 1949
Thanks for this I knew that the number converted to the new numbers I just didn't have the list handy.
I own several 30T2, 30, 30T2 Rg Omegas and serviced at least 20 of 30mm Omegas - not even once I saw what you described as "sealed canon pinion" on these watches. Yes, the top of the Pivot is always nicely finished (not applicable to sweep second), but it is not part of the Cannon Pinion.
I found the parts list it was lurking in my computer.
My bad I based it on the picture way up above and it definitely looks nice and shiny. But based on the UK ones looks like you should Be able to drive it off. Just make sure you support the cannon pinion as close to the center wheel is possible you don't want to break any teeth off.
357_260_complet_2015.pdf
    • Not a family member, and yes, it no way near as good, as some information got lost from original site and some information got incorrectly copied. The original site is available as iOS app here: https://apps.apple.com/fi/app/ranfft-watch-movements-archive/id6502008939
    • Outstanding, Marc! Your information is really helpful and clears this up, especially given that yours were purchased as sets. Thanks, man. So, it appears I jumped the gun on this one, but I am relieved. I will say, though, that all of my reamers and concave pushers are number-stamped and appear to be of better quality.  Also, the bayonets on my pushers are actually the same color as the steel.  The next thing to do is restore the heads of these pushers with some polishing paper.  Alex at the Watch Repair channel has a nice little video on this.   I appreciate your help! Frank
    • Just installed it on my iPhone (my only iOS device) and it appears to be intact and functional. I may have to go out and buy myself an ipad just for this app.
    • I have two Seitz sets, one ancient (with the 3mm anvils) and one just old (with 4mm anvils) plus a collection of spare pushers of assorted vintage. Not one of them is marked with it's size. Something which I have found very irritating when I have been using the tool and not returning pushers to their correct place in the tray every time as it means that I have to get the calipers out and measure them. These were bought as sets and collectively I have over 100 pushers so it would seem highly unlikely (if not inconceivable) that they are all cheap knock offs, especially as they are old enough to pre-date the prevalence of the Chinese knock off industry (at least as applied to watch making tools). I therefore believe them to be original Seitz parts. And there is no numbering. The shape of the bottom of the pump pushers is the same as your photo. The only thing that may not be the same is that the slotted insert (looks like a screw but is in fact a bayonet) should be brass. Yours looks the same colour as the steel but that could just be the lighting.
    • The original database is available on iOS devices here: https://apps.apple.com/fi/app/ranfft-watch-movements-archive/id6502008939
