Ronda Matic 1239 advice please
Birdie
I have a Sicura with a Ronda Matic 1239. It’s a long story, but basically I sent it for service and it came back worse, so I decided to have a look myself. I’ve already found one fault and rectified it but I have now discovered that when releasing the click there is no power coming through. (Even after manual winding) I have concluded that the main spring is broken / not engaged. I don’t like to knock anyone because we all have bad days but is it possible that the chap put the barrel / spring back incorrectly. It worked fine before I sent it. Any help greatly appreciated.
Thank you all for your advise. I will have a go myself. May I ask further advise please. Does anyone know if the automatic winding unit comes off as a complete unit or will I have to dismantle it to the component parts. Again any advise will be really appreciated.
Thanks very much for this watchweasol. I have looked at and pondered over it for a few days and although there is a spring that holds a gear in place it is fixed, so I’m struggling. As a novice I’m reluctant to start dismantling the auto  mechanism if I don’t have to. However assuming I have to does any one know in what order the screws have to be released. Sorry for sounding dumb. I have attached a photo in case someone recognised how best to do it. As always I really do appreciate your help and guidance.
Once the rotor has been removed  you are left with the bridge, loosen the bridge screws, at this point take a picture, remove the screws and place aside and using a screw driver loosen the bridge care fully when loose remove carefully taking pictures at each stage. you will now have the rotor and the bridge off the movement and the procedure photo documented.  If you are dismantling the movement again photos at each stage to aid re assembly. You can't take too many as they will augment your memory on the rebuild..
    • Hello good watch folk ,I  just fancied a light hearted discussion after my head was starting to spin over Epilame 😅. Specifically I'm meaning the sale of vintage watches, say nothing past the 1980s market. The stuff we see on ebay and other similar sites and found at carboots, curio shops etc. And are  we thinking its reaching a peak volume ?  Younger generations clearing out passed parents and grandparents possessions.  The younger folk are not as sentimental as the old fogies ( I'm now nearly at an age that i used to think was old fogie age ). When might it have started ?  i often wish i discovered the hobby much much sooner when selling your grandfathers pocket watch at a boot sale for a few quid was just a way to offload some tat. And when might it slow down. Thoughts anyone ?
    • Yes i did eventually realise that the oil will act as a barrier, I'm sure the discussion will continue. Ive had two oleophobic coffees ( added coconut ) and in the meantime i have this just delivered to take my mind off epilame for the time being. My favourite type of dial, its a beautiful looking watch traditional English made and it runs,  the ticktock is phenomenal,  i can hear it across my living room .  You wont believe how much it was. Thats interesting about synthetic oils , i thought the same, going from a 2 year service to 5 years is a big drop in income for service folk.  I expect some did well when they embraced the use of synthetic,  probably drawing in more customers than those that didn't use the new fangled substances , i bet fairly short lived though. The more frequent service makes more sense to me, not for just the service but for the regular check up inspections that might pick up impending faults. As far as epilame goes, wouldn't it be great to be able to fumigate the complete movement in a sealed jar of heated stearic acid, 🤔 now theres a thought 😅.
    • Imm going to close the discussion by attaching the photo of my super-titanium after several vicissitudes finally working. Purchased as not working I replaced the battery and for a stroke of luck I found its semi-new solar panel which, having verified its operation, seems to recharge the accumulator perfectly. I had taken this watch almost by bet, with 40 euros I brought it back to life. The initial half idea was to resell it to finance another purchase, but.. it's definitely a nice item. It would need to check the impermeability but it's a pleasure to see it on the wrist 😃
    • In fact the secret is to go gently and find the way without forcing, and the movement enters without problems
    • Yea a have given it a full service this movement is chinese 2813 whats the lift angle for this movement does anyone knows  and how  do a remove the default  of 52 degrees on my timegrapher?   Hi you said my lift angle is default how do a remove this from my timegrapher?
