Waltham Traveller, First Victim?
I've got a Waltham Traveller pocket watch,,,from the serial number it dates as 1917.
I use to wear it, but it broke. I took it to a repairer, but the main spring is broken and the winder is slipping. There's a sleeve inside with 4 paws on it which engages the winding mechanism when pushed down? These paws are gone, so when you push the crown down to wind it, sometimes it catches, sometimes it don't, just spins around.
The repaired can't get hold of the winder part. So it's pretty much scrap.
The question is,,, can I try to repair it myself,,,would it make a good first victim? Or are the watches a bit too complicated for a beginer?
Can I do the main spring myself? Is that possible without a winding tool?
Also, the winding mechanism,,can these be sourced from the web, or would it mean buying a donor watch?
Sorry, loads of questions.
Thanks
Mark.
Thanks clockwork.
Only got some basic tools at the moment, bought a screwdriver set, tweezers, device to take the hands off, loupe, and little pliers.
Will have a look for some YouTube videos.
Sourcing parts, I haven't got a clue where to try there? Is there anywhere/one that stocks parts for these watches?
The main spring, can that be wound by hand or does it require the right tool?
Thanks.
Agree with Blacklab it,s also best to be prudent to start with when buying tools & if budget allows buy the better quality tools.
When you strip the watch it,s a good idea to take plenty of pics as you go for reminders when you re-assemble & don,t force anything as the pivots are delicate & are easily broken.
On some of the older Waltham pocket watches, the crown and stem are part of the case - not part of the watch movement. When you take off the back and undo the case screws, you have to pull out the crown to its fullest extent before taking out the movement - otherwise you can break the winding stem - which stays with the case.
However, I'm a little puzzled as you say: "There's a sleeve inside with 4 paws on it which engages the winding mechanism when pushed down". You shouldn't have to push the stem down - or pull it up - to wind to wind the watch. The crown is normally pulled out to set the hands - unless the watch is lever set - and you just wind the watch with the crown and stem in the normal position. Or have I read you wrongly?
I can't be sure without seeing the movement, but irregular or slipping winding sounds like a faulty click mechanism. Any pics you can post?
Cheers,
Will
Edited by WillFly
Hi,
   I checked a picture of a Waltham Traveler and I would think that The stem would have to be part of the case. Inside the case tube there is a sleeve which can be adjusted with a sleeve wrench. Now I could be wrong as I am just guessing but from what you have said I think part of this sleeve near the bottom has a part with four small pieces called the boss and I'm guessing this is what has worn away?? Without this part your stem can't work properly. Now the good news is that should not have any effect on the movement and if you replace the mainspring you should be able to watch the movement spring back to life. Getting back to the sleeve as it is part of the case you can find cases and non working entire watches pretty cheap.
Charles K
Thanks guys.
Hopefully see if I can get a few photos attached to this.
The crown pulls up to set the hands to alter the time, and to wind it you push the crown down and turn. It's when you push the crown down to wind it slips. I took the movement out of the case and looking where the winder shaft fits,,there's like a little piece at the bottom. If I insert the winder shaft or a small screwdriver this pushes down,,which I imagine engages the winding mechanism when you turn it?
I also took the mechanism out of the case,,that looks ok?
post-760-0-08157100-1426955019_thumb.jpgpost-760-0-14510900-1426955036_thumb.jpgpost-760-0-96333700-1426955066_thumb.jpgpost-760-0-35466100-1426955081_thumb.jpg
Hope the photos are ok.
The stem and sleeve look to be in good condition. The depth of the sleeve does have to be set correctly so that setting and winding functions engage and disengage correctly. If the winder is slipping the I'd try 'tightening' the sleeve a bit.
That said, how do you know the mainspring is broken? Does the watch wind and wind forever? Do you feel a bit of resistance when winding then it slips?
Try winding it outside the case. See photo.
That said, how do you know the mainspring is broken? (A) Does the watch wind and wind forever? (B) Do you feel a bit of resistance when winding then it slips?
The answer in both cases with a manual wind watch is yes, and with a watch like yours it would be a good idea to confirm your suspicions by winding it out of the case.
Just as an aside, if you have an automatic wrist watch that can be manually wound, it will keep on winding forever if manually wound as the mainspring is designed to slip inside the barrel when fully wound.
Thanks wileyrover and geo.
Just tried lifting the little lever up and winding,,,,it goes a couple of turns then it slips, you can feel a slight "clunk", when it does.
I did take it into a watch repairer, that's who said the main spring was gone and the winder shaft was worn. He could get a mainspring but not a winder shaft/sleeve. So, more or less scrap.
I've just won a similar movement off ebay,,described as semi-working, So will see what that one is like and will give it a go to swap the parts over, make a working one out of the two.
Well, no. Definitely not scrap.
The mainspring is an inexpensive repair. Springs are readily available. It's also possible that the spring is not broken but one end is slipping off the barrel arbor or the hook on the barrel itself. Have to open the barrel to check.
Not sure what the meant by "winder shaft" but if its the threads inside the stem tube that the sleeve threads onto than I supposed it would have to be re-threaded or switched with a donor case.
I know when the watch was working, when you pushed the crown down to wind it, it would slip, not all the time, just every few winds. That was till the main spring went ping.
The bloke I took it to, described the winder part, as a shaft with 4 lugs on it,,and that 3 of these have worn off, that's why when it's wound the crown slips. He also said about there being little springs in there. So if the part in the case is ok,,,there's the winder mechanism in the main body,,,could this be the part that has worn? See if I can attach a photo (courtesy of a ebay photo), of the part I mean.
I've taken many pocket watches apart and can't for life of me figure out what he meant by a "shaft with 4 lugs". The only shaft would be part of the watch case. Not the movement.
The only spring in the setting mechanism of the watch movement itself is under the circular disc in your picture. In it's natural position, it keeps the watch in setting position. Pushing in the crown or pulling out that little lever on the edge of the movement pushes against the spring and the puts the watch in winding/running mode.
With the movement in the case, did the crown stay "clicked down" when pushed in? Or did the crown keep popping up on its own?
Yes,,I had visions of a shift/sleeve with 4 lugs on it,,but looking at the mechanism, there's nothing that would match that. Ive never had a watch apart before, so this is all new to me, but hopefully will learn from it.
When winding the watch, the crown would always spring back up on its own after being pressed down to wind.
When winding, you would hold the crown between your thumb and finger, press the crown down and wind it as far as your fingers will move. Then you let go, the Crown will spring back up. You then press down with your thumb and finger again and wind again.
Sorry if that description, sounds stupid.
When doing that, sometimes it would wind and you can feel the ratchet clicking,,,but then sometimes it would slip and there will be nothing,,it would just spin. So you let it go and press down again,,it would slip a little bit and then catch and start winding again. Some part of the winding mech is not always engaging?
Difficult to describe on here, but hope the description above helps.
That description clears it up. My best guess is there are two separate problems that need to be addressed. And both may be very easy fixes.
1. The main spring barrel needs to be opened and you need to see if the spring is broken or if it's not catching the center arbor. Sometimes when they slip a few times the force of the spring slipping opens the inner coil of the spring even further which makes the slipping worse...until it won't catch at all. This can be repair by gently closing the inner coil with some pliers so that its tighter around the arbor.
2. If the stem isn't "clicking" firmly in place that will cause all sorts of problems when winding. These fingers can often be bent slightly inwards so they engage the stem more tightly. Pull the stem out of the sleeve by pulling on the square end. Squeeze the fingers slightly inward. Reinsert the stem and see if it "clicks"
Edited by Willyrover
The spare movement arrived, described as working intermittently, but I wouldn't get it to work, completely dead,,oh well.
So following a video I stripped it down, so far so good, no flying pieces, all nicely safe in little pots.
I wanted to open up the main spring barrel to see the spring,,but it won't come apart!
The arbor came out, but the 2 halves of the casing won't seperate. They will come apart very slightly,,but it looks like the spring is joined to the flat,toothed half of the casing.
I don't want to try to pry it apart in case I damage it.
Is there a way to open this up?
Never seen a barrel like that. Usually the arbor won't come out until the cover is taken off the barrel.
What does the arbor look like?
Can you tell if the spring unwinds against the silver portion of the barrel?
Or is the silver portion a cover that slides over a brass "wall" that the spring unwinds against?
Got the barrel apart, with a bit of careful prying and twisting.
In the wall of the barrel there's a notch for the spring to catch on, while on the brass lid part the centre comes down with a notch for the spring to catch on that part.
There's nothing on the arbor for the spring to catch on,,that gets pushed thru from the outside.
If you wind the spring into the barrel,,how would you get the middle to catch onto the notch in the brass lid part?
You'd wind the spring into the barrel then manipulate the brass cover onto the barrel so that the inner coil of the spring is around the part with the notch.
Then rotate the brass cover until the notch engages the hole in the spring.
    • Personally I would salvage the missing screws from some donor movement.  I also bought a random selection of screws "Assortment of Stainless Steel Watch Screws" for next to nothing.  As for using an Alum solution - I had great success with that removing a rusted stem from a stainless steel crown.  The best piece of advice I read on doing that was to keep the solution warm so that the reaction didn't take weeks!  I did it in a couple of hours with the solution in jam jar and the jam jar in a saucepan full of water which I left on an induction hob maintaining about 60C in the Alum solution.
    • I decided that it was time to tackle the piece that I'd set aside as my first project. The subject in question is a Gruen Veri-Thin pocket watch.  It winds and "runs".  On the time grapher, it has reasonable amplitude (240 or so depending on the position), but was loosing close to a minute a day.  The stem also has the annoying tendency to just come out when pulled, which makes it super hard to set the thing.  As with many things this one started sideways and just got more so.  I was able to overcome the mangled "tab" on the back case cover (a well placed, very sharp knife enabled me to get in when I couldn't get a purchase on the mangled tab with a case knife.)   I was then sort of shocked to find that one side of the dial was held down with some sort off tape or adhesive material as someone had broken the dial foot screw on that side and left the broken screw in the mail plate. The loose stem does in fact seem to have been a poorly tightened setting lever screw, but I'm afraid there may still be gremlins in the keyless works.  While I was able to get the stem to stay in by putting everything in the right place and tightening the setting lever screw (before I took it all apart for cleaning and inspection), it just didn't seem to all sit right. The final gremlin showed up when I was taking off the lower cap stones for the balance and escape wheel (yes the Gruen 380 seems to have a cape jewel on the escape wheel).  The balance stone came off fine (but that in fact is the smallest screw I've ever seen.  When I turned the movement around to get the one off the escape wheel setting, I found that the screw head had been mostly sheared off.  After some reading and looking at what I had, I decided to try and tease what was left of the screw out of the hole by nudging what was left with the corner of my smallest screwdriver.  After 20 minutes or so, I was able to get the remains of that screw out. The picture I'm including of the disassembled movement was taken before I got the second cap stone off, so in the picture, it's still attached to the main plate (for those looking carefully, you'll only see the one cap setting in the pic.) Now I'm left with: A broken dial screw inside the main plate that needs to come out A broken cap stone retention screw that I have in my parts tray, but that is strictly useless and needs to be replaced. The need to get another dial foot screw I'm contemplating solving the first problem by soaking the main plate in an alum solution.  I think the main plate is brass and shouldn't be affected, but I have not been able to confirm.  This seems like the easiest option as I can't really access both sides of the screw to use the pricey Bergeon tool (which I don't fancy buying unless I have to.) I have located a couple of donor movements and have questions out about whether or not the include the dial foot screw and prompting for pictures of the dial side so  evaluate the cap stone settings.  I've also found that a supplier in this country does have the cap stone settings, but isn't overly clear about whether the screws are included. Are these the types of things that one can scavenge out of assortments or is it best to just grab one of the donors assuming that they look like they have what I need?
    • I visited this place last year just before they closed their counter service - amazing shop (filled from floor to ceiling!) and the guy that was working there was really knowledgeable and helpful!. Their website isn't as good as Cousins but I understand that if you fill out the contact form they have stuff that isn't on the site. https://gleave.london/mineral-flat-bottom-domed/
