Don't Look Up
I had the same effect with the double glazing. If I looked out the window at an oblique angle I could one image on the inside pane. This probably means my windows need cleaned!
I took my pics outside :) I am scratching my head over the double flare. But I would guess it is caused by the different bits of glass in the lens. I don't know to be honest, not an expert on lenses.
    • Hello everyone. My name is Gary.  I’ve been hobby fixing for just a few months now and have turned out several Seiko 7009A, 6309 and 7s26 movements with varying success.  my first movement was a tiny Cyma 424. (In at the deep end for size).  I’m currently working on a sentimental Garret ETA 2391 for my Father in law.
    • Thanks for all the replies.  I'll investigate further.  I never noticed the lip and @Michael1962, I think I will have to form a tool to undo the ring and see what happens. I'll see if I can get some more pics.
    • Hi John, The most important parameter of the spring is the thickness. The lenght is something that one would not consider as obligatory, as relatively big variations will not affect anything in significant way. The barrel size is related to the barrel and has nothing to do with the spring. Yes, the spring is designed to work in a barrel and the size of the barrel matters, but let this parameter be chosen by the movement manyfacturer, not by the sping manyfacturer who doesn't have idea in what kind of movement the spring will work. Sometimes the washer in which the spring arrives will be bigger than the barrel and there will be no way to just push the spring in the barrel and be happy. Well, if this is a problem for somebody, then probably He is a person with to many problems that will be verry hard to help to in any way. By the way, why You are changing the spring? Is the old one broken?
    • Lets give it to the end of this month to get all the votes in, then we can call it?
    • OK, I have created a solution to the above, I have made a fake protonmail account, if you PM me I can send you the password, just click on the contact link and enter your information, this should be as secure as it gets:   Website:     Link Login: email as highlighted in above screenshot WRTArk    @   Proton.    me Password: ..........PM me and I'll let you know   Only intend to use the contacts function, not the email or anything else - we are all grown ups, please act responsibly.
