I have replaced a battery in this watch and the power drains immediately.  There is no insulator needed.  Anyone have any input
on what might be wrong or if I'm doing something wrong?  It is movement #8F32A with a 2412 3v battery. Thanks
Have a look at Mark's video.
https://m.youtube.com/watch?v=F3hVre1yf_k
Thanks George , ...I have seen this video several times , I just didn't realize it was an 8F32 movement...
 I don't watch television  ...everything I see is through my computer  and I think I have seen Marks great videos more than anything else . I will start to work on a watch project about 9 or 10 PM until about 4 AM , put on some music and run Marks videos for company ......  I gotta get a Life ..... someday
Hey George , What kind of bike is your Cafe Racer ? It looks nice .
Hi Ricardo, that was my Norton back in 1972.
When I purchased it in 1967 at the age of sixteen it was a standard 1958 600cc Norton Dominator. The first thing I did was take it to bits and get looking as close to a racing Manx Norton as possible. In 1969 I fitted a fully race tuned 650ss engine, and in 1971 I replaced that with a 750cc Atlas motor. Unfortunately it met it's demise in 1972 when I was travelling at a fair rate of knots and a car pulled out in front of me. :( The only thing that remains of the bike is the registration number which is fitted to my car.
Is that a Tiger 100 your sitting on? My current transport is a 900 Triumph Trophy. :)
My motorcycle was a 2 cyl. Triumph Trophy 500cc  1 carb . I had just had the engine and trans . rebuilt at the local Triumph shop and had a custom Emron  painted tank with the Triumph logo done in silver leaf . Wish I still had it . I always loved the Triumphs , Norton's , and BSA's . I used to go to the flat track races in California and they would run those and the Harley sportsters . You can see my Uncles Chevy in the background of my pic and estimate the year  .
The 500 Trophy was an export only model and better finished than the bikes we got in the UK. A friend of mine managed to acquire one back in the day and I rode it a few times; a lovely bike! B)
 it does sound to me like a short somewhere . You might asking member George Clarkson...he has experience with this type of Seiko .
attachicon.gifSEIKO_4F32_8F32_8F33.pdf
Oh I nearly forgot, welcome to the forum Joel.
Thank you ricardopalamino and geo.  I did have that PDF and I did watch Mark's video.  Unfortunately, neither could help me determine why the short is occuring.  I'll keep trying
and thanks again for the replies!  Joel
Contrary to what ricardopalamino said, I have not that much of experience in this particular watch, since I tend to focus my attention, when it comes to quartz watches, to Seikos 7Axx and 7Txx chronograph series. I would recommend, though, to check the coil: I had a similar issue once on a 7A38 where the coil was damaged, and the battery didn't last more than a month. Switching the coil to a good one, apparently sorted the problem. After 1 year, the watch is still working with the same battery.
You should look on the technical manual the value of the coil, and compare it with yours. This is the only thing I can come up with, sorry.
George Clarkson
George Clarkson
Thank you George.  I appreciate your input!
Joel
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
