Manufacturing Seiko lume pip for 6309 7040. Using a staking set and peice of plastic from bergeon packaging which is the right thickness, once in the bezel I will relume with c3 and post more photos
On 11/28/2020 at 1:57 AM, Graziano said:
The lume binder holds the new pip in place.
Excellent job I have a pip missing from my Vostok diver and need to figure what to put in the opening.
Hi there jdrichard, thank you, I would use some uhu 2 pack glue and mix it up with some lume of your choice, make sure you mix a good portion of the lume in the glue as much as you can get in the mixture and use an oiler to place it in that pip holder. You can dome it or fill it flat. Make sure you don't touch it with anything for a couple of days. It will dry looking like a lumed glass pip. It will stay there as it will be glue and lumed at the same time. I think it would look cool with bgw9 to add a bit of colour in the dark. The choice is yours my friend
Regards Graziano
Edited by Graziano
  • Thanks 2
Fantastic . Going to steal this method from you. Have done some with Lume and clear epoxi . But this would probably look better. And more original. Epoxi and lume would work fine on the Vostok
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
