Rolex 3035 after coa issue
Yallabye
Hey guys, so I’m having a problem with potentially the balance and or escape wheel. Did a complete coa on this movement. Also replaced the upper escape wheel jewel/spring/setting. Now the watch runs but, on the vibrograph shows a lot of time loss. When I press down lightly on the balance bridge a bit it stops, and have to turn it to get it going again. Been stressing me out. Checked all the pivots and jewels and everything seems fine. Any and all info would be very much appreciated!
Edited by Yallabye
Since you replaced that upper (in the plate?) shock setting you probably pressed it too far and now you have no end shake at all. You need a tiny bit of shake there. Less than the train, but more than zero.
Was it a Rolex part, or generic?
There is a bit of endshake. Is it supposed to be flush on the underside or have a very tiny bit of lippage? It is all genuine.
So you got some or little endshake,  just as a test: loosen cock screw 1.5 turn see if oscil speeds up.
 Do you see any shelac keepin pallets put?
You beat me to it, while I was compsing. fast typer.
Sorry can you please explain what the cock screw is and “shelac keepin pallets”
Cock screw is the one that holds the cock down on mainplate, in cases you suspect end stones might be pushing on pivot end( no or very little end shake) you can releive such possible pressure on end stones by loosening the said screw, if the are no end stones, the jewel itself can be pushing on shoulder seat of the pivot.
Shelac is the stuff that acts like glue but wont hurt the base metal over time, it is used on fork pallets jewels to keep them from moving in fork slot, nearly all petrolium base cleaning solutions dissolve shelac rendering pallet jewels loose to move in the fork slot, which ruins escapement at the pallets and can be a cause for a host of escapement disfunctions.
The amount of exposure doesn’t matter- the end shake does. Try Joe’s idea of loosening the cock screw and see if things improve. If so, you may need to press the setting out a hair.
Did you happen to do any hair spring work? At rest, is the roller in line with the pallet fork (straight line between balance pivot, fork and escape wheel)?
Ok so Adjusting the cock screw did help a lot but it is still about 1 minute 45secs losing still. I am going to press out the upper escape wheel setting and see if that makes it better, I’m hoping
out of curiosity why did you replace the entire setting?
normally the above answer would be fine except this is a Rolex watch. Rolex is obsessed with end shake so often times they will have procedures to make that adjustment easily especially on the balance bridge.  rather than explaining the procedure I'm attaching a section out of the manual. You'll notice there's a screw specific for adjusting the end shake. If somebody had zero idea what that screw was for an rotated it that would be the problem.
I replaced the entire setting partly because I was lazy of replacing just the spring itself because whoever worked on it before had broke half of the spring and left it like that so I decided it was easier just to replace the whole thing instead.
I adjust the regulating screw for the balance bridge, and also pushed the setting  in a bit more so the escape wheel has less endshake and seemed to make a huge difference. Within 10 secs.
Checking end shake on escape arbour will suffice. You would get zero end shake, if end stones are pushing on escape pivots.
Removal of end stones so to leave escape arbour unbound might create new problem, that is; you want escape wheel and fork pallet jewels level (both in same plane).
You have high percision gears in this piece, so power transfer through out the gear train should feel effortless.
 Thanks to john's post which shows the design provides an end shake adjustment screw.
Good luck.
    • Date (day) CAN be moved without issues from the crown (position 1) but it CAN NOT be moved by rotating the crown (position 2), nor does it move in a normal 24hr. cycle. Clock functions otherwise withiut issues. Brand new Renata. Thanks, V.
    • Visually pocket watches suit some people. Having bigger parts to work with makes things a little easier to understand, the con to this is older timepieces that have been messed around with. Teachers recommend starting with something new and in good working order, this way if it doesn't run after you have serviced it then you are only looking for a fault that you created. That didn't suit me though because I'm quite mad with a little crazy mixed in 🤪
    • Got it thank you! I'll steer clear of the lower jewel count movements until my skills are a bit better. I'm literally brand new to this
    • Depends where you are with repairing, watches like you have just mentioned  the Smiths, Ingersolls, Services are often pin pallet watches with low jewel counts, not impossible to fix but often quite difficult due to having more wear than a fairly standard 15 or 17 jewel movement. Saying that you may be lucky and pick one up that was never used much. As an example i spent a few weeks on and off getting the most i could from an old Smiths Empire, that did actually finish at within 2 minutes per week that could be improved further now i know it is fairly precise but not quite accurate . Sekondas are good practice pieces at around a tenner, though some folk call them rough but robust.
    • Hello people , this is maybe a question that the moderators can answer.  Can seperate posts be unmerged from each other. Sometimes posts are missed by others because of a continuation of them . Even when answering seperate people the posts are grouped together as one. Maybe it saves message board space ?
