Problem solved. My initial lamp was not rated for dimming and worked for 10 seconds vs 45 Years on the box. Returned it and went to a different store where I picked up an industrial shop lamp and fixed to an overhanging shelve. Then I bought an inline dimmed switch that is where my desk lathe switch is and it all works like a charm. The light can be adjusted to 10% and at 100%, I could get a tan. Here is the box and shots of installed location.
58 minutes ago, Tudor said:
Looks fancier than mine, but certainly does the job!
Had to do a little wiring. Really works great. Says it lasts 27 years. Funny, they know no one is coming back 27 ya ears later for a refund.
3 hours ago, oldhippy said:
OK I know I'm an old fart, desk top computers where not around in my days. Why do you need not just one monitor but two?
Only 2, amateur.  My home office setup has 4.  For work I use 1 for my code, 1 for what I'm coding, 1 has the log messages and the last is used as overflow if I need to reference code from another project or watch youtube!
I actually have 3 monitors. The third one is mounted on a laptop holder and is above the right monitor and is for work. I have a KVM switch to flip the big monitor to a work computer extension while my personal computer still shows on the right monitor...all by a remote control. I think I need two more monitors:). I am an Engineer so I need to out-nerd my friends.
That is a lot of coding. If you code correctly in the first place, only one monitor needed:)
  • Haha 2
So there nothing to do with horology. A funny place to keep such things. I would have thought you are using valuable space and it makes it easier to misplace parts.
A typical engineer response!  ?
Also why I try to keep things neat, it's much easier to find those springs on a tidy desk.
Not much challenge in that, now is there...
(from the engineer that can't see the top of his desk)
  • 1 year later...
Needed for work:)
  • 1 year later...
    • I did wonder about the feasibility of mixing two oils. I am guessing that 9010 / 9020 or HP500 / HP1300 would be a better mix than 9010 / HPxx. Some people might think that was heresy but I guess the only consequence is that you might have to service the movement again if you got a poor result.
    • Believe me: I am aware how fortunate I am.
    • Yes, however, as you are just starting out, you can progress using Ronsonol lighter fluid (or equiv) to clean.  Use pegwood to clean all pivot bearings. Yes.  Some disagree with me.  I have many hundreds of dollars invested in multiple time graphers and vintage timing machines.  The phone app is just fine for a beginner. Probably just needs a good cleaning. My SWAG, is slim to none unless you own a 3D printer and can design and print a spacer Here is a re-cased Mickey Mouse watch I made using 3D printer...lol!!
    • Chances of fitting that movement into a modern case with pleasing results are not good unfortunately. Dial size, pinion height, the position of the stem relative to the thickness of the movement all play a role, so cases made for a specific movement are really only workable for that movement. If you have a lot of skill in 3D modeling you might find a way to make it work, but it would be a significant challenge. A case made for an ST36 would be gigantic in relation to the Benrus movement. A case made for something like a Seiko NH35 would be closer to a workable diameter, but most of those modern cases are made for automatic movements that are much thicker than vintage hand wound movements.
    • Thank you very much for the very helpful info, folks. A lot of reading to do! I do like the look of that ingersoll. I am in the UK, so I think moebius is more readily available than Elgin. I hear 8000 does the trick as a jack of all trades. Given the rather sorry state of the Benrus, if I get the movement to run (If wound, it ticks for about 2-5 seconds then stops. Give it a tap, it ruins again, then stops again), What are the chances that I'll be able to fit it into an ST36 case (perhaps with a 3d-printed adapter)? I don't think I'll have the spare cash to invest in case re-plating and dial re-finishing! I would really appreciate some info/links on how to clean the parts: is it achievable without a ultrasonic cleaner, or am I better off buying one and not wasting my time? Also, can I get away with a timegrapher app on pc/phone?
