hermle 340-020 movement not running
arron
Hello,
I am working on a 1977 hermle 340-020 movement that has been wound tight and hasn't run since at least 1994.  it has a floating balance.  before deciding how or whether to repair it I would like to try and diagnose the problem(s).
    The movement looks to be in excellent condition although I can see a bit of crud in some of the pivots.  Although fully wound, when I push the balance wheel it moves for just a few seconds and stops.  I then took the balance wheel out and moved the pallet fork back and forth and the escapement wheel does move; but if I just touch the pallet fork on one side it doesn't pivot on its own to the other side (as though it's not getting enough power from the mainspring).
    Also, when I put the minute hand on and turn it manually I'm not getting any movement from any of the wheels as I would expect if it were trying to strike or chime.
    Are there any tests that I can do to pinpoint where the issue(s) might be without further disassembly?  Much thanks for any insights.  Be well.  Arron.
Ps while writing this, the chime side started spinning but only when laying down, not upright.  And a bit later, when I turned the movement over on the other side, the strike side started spinning.  not sure what all this means.  maybe it just needs a deep cleaning and new springs?
The Hermle movements are quality, from your description of the problem it is in need of a good service this includes removing the mainsprings from the barrels and cleaning them and barrels also  The floating balances are self contained units an must be treated with care.  Remember to remove the power from both springs before doing anything.  There is a Hermle clock manual, I got mine from Cousins its a mine of information.
Looks as if its as dry as a bone. A clean and oil I think all is needed. To be fair you never know until you take it all to pieces and checking the wheels such as pivots,teeth,pinons and the pivot holes. These movements are made of a soft type of brass and steel.Always use a good mainspring winder to remove and re-install the springs. When it comes to the floating balance both ends should be jeweled, a tiny drop of oil on both ends then work the balance up and down a few times to make sure the wire is oiled and that should keep the balance nice and free and floating. Oil the pallet pins but not to much and every other tooth of the escape wheel. The rest of the movement should be oiled in the normal way.
  • 3 months later...
After your good advice i cleaned the movement and put it back together.  The springs all looked fine to me.  the time train seems to be working well, but the chime and strike side are acting weird.  when i turn the minute hand there is no striking or chiming until i get to the top of the hour, then it chimes.  at that point the gathering pallet turns at most one time (or a partial revolution), pauses and then turns one more time.  no matter how many times i turn the minute hand, the gathering pallet never climbs the entire way up the rack.
i don't put it passed myself and my skills that i put something back the wrong way (i did that on the chime side and luckily figured out my error).
another observation i just made is that in the middle of the chime, the bar that raises the striking hammers lifts and holds those hammers up while it's still trying to chime.  and at the end of the chime, the striking hammers bar lifts again holding those hammers up instead of leaving them down in the resting position-it doesn't do that every time though.  sometimes a chime only hammer will be left in the up position.
it's a mystery to me what's going on.  Any advice appreciated.  thanks.
You haven’t got the strike and chime set up right. On the centre wheel you have the cannon pinion with four points on it, the shortest is for the quarter past then half hour, a quarter too ant the longest is the hour. The cam wheel has four grooves in it the shortest space between the grooves is for the quarter past and so on until the longest gap is for the hour, you need to have both in line. The strike side the wheel with the pin in it next to the fly wheel should be set about 10 to the hour. Make sure the wheel that lifts the hammers is completely free from lifting the hammers, all hammers must not be in the way of the wheel when it comes into the warning that is when the hour hand is about 10 or 5 to the hour. The gathering pallet must also be away from any of the teeth on the rack until it starts striking. Let me know how you get on with that it probably will need fine adjustment.
I have found this it will help you.
  • 4 weeks later...
    • Yes, I was referring to the (jewelled) gear train with HP (most of the time, I use 1300, but when Rolex says 1000, I'll use 1000).
    • did I miss the update of the message of something changing?
    • I suppose it would depend upon what your lubricating with those? for instance what does the manufacturer say about those lubricants? I have a PDF from the manufacture and a rather peculiar statement found on the bottom of the chart. my suspicion is the reason the recommending would be without epilam the HP oils like the spread except when they're in Ruby jewel's with steel pivots. tableEN lubrication 2020.pdf
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
