Put Kundo clock in beat
Willow
Help how do you put Kundo in beat or even know if it's in beat. Strip cleaned oiled new suspension spring clock working but running slow. I have heard different opinions about the beat setting tool and don't know if it's worth buying ? looked at different video's on setting The beat but can't get my head around it
Ok this is a reasonably simple job. First the pendulum must be absolutely in the middle of the lower cup (ie absolutely level). To judge being in beat the pendulum should swivel equally in both directions. Some put a graded card underneath but I just time in seconds each turn. To adjust I believe it is the screw at the top that you adjust.Looking at your vid its not far out BUT why the wobble is the suspension spring absolutely kink free. To regulate just turn the wheel I have highlighted.
When setting the beat, watch the Escape wheel, and the pendulum, at the same time!
What you are looking for is an equal amount of over swing, as the anchor releases the escape wheel.
Having a marker on one of the balls will be helpful.  As will having movable  markers on the base, two for the full extent of the swing, two for when the escape wheel is released.  When the escape markers are equal distance from the full extent markers, the clock should be in beat.
Beat is adjusted by the screw head shown in the red ring above.  A very small movement of this screw will have a great effect on the beat.
Once the beat is set, I would allow the clock to run at least a week, before attempting to regulate.
At that point the clock, (assuming still running) it will be running fast or slow, adjust by turning the arrowed wheel, in one direction only.  If the adjustment runs out before regulation, then the suspension spring will need changing, either thicker or thinner.
Bod
The beat adjustment tool is extremely good in getting these clocks in beat. You attach it the part that holds the top suspension block, because it has a long handle you are able to get very fine adjustments to put the clock in beat.
If your clock is   wobbling like that it tells me the suspension spring is't straight. After the pallets escape one tooth the pendulum should carry on with its swing then swing back ans escape its next tooth carry on with its swing and both swings should be even. Bad suspension will cause problems.
Hi  If you have Terwilliger's book there is a graph in the rear section for you to copy as an aid to the timing of the swing and overswing. The wobble is a bit disconcerting.  Again might be prudent to remove the suspension and check it against Terwilligers guide as the suspension may have been changed and the fork is wrong. Although if that's the case it exibit's either skipping or not unlocking. Removing the suspension will enable you to check if its straight or not.  The use of the tool as advocated by Old Hippy enables micro adjustment of the top block and is more sensative than pliers. I have used both methods and the tool comes out tops. Not cheap but essential if working on these clocks.
Thanks everyone for your input yes watchweasol i have the book so will look at the page you mention and I think I will change the spring to be sure i haven't somehow put a kink in it
Edited by Willow
Spelling
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
