1979 Timex quartz M56 stem
MartinM
Hello all, I have a 1979 Timex Q quartz watch with M56 movement.  When I disassembled the watch for maintenance, I messed up the stem.  I can now easily pull the stem all the way out. So now instead of setting the time, I have the watch in one hand and the free stem in the other.  Does anyone have advice on how to secure the stem properly?
thank you, Martin
You need to bend the brass tab circled in red back up into place to hold the stem. You must have pressed too hard when removing or it was a already deformed. In the hand setting position the brass tab stops the watch when it contacts another brass strip that goes to the circuit board and stops the stem from pulling out.
You may have to remove dial to do this operation.
Love these jump minute watches!
Thank you so much for the welcome and for the advice!  I was able to adjust the contact from the dial side, pushing it back into place to secure the stem.  In the patent for M43 (similar to M56) it is part number 46 that needed to be adjusted. And it is this same part that needs to be pushed a bit out the the way to remove the stem.
The watch came to be in bad shape and needed to be cleaned, oiled and polished.  Now the watch is running well and yes, the jump minute is very nice!
I added images of the drawing for part 46,  the dial side of my watch with the exposed piece of part 46 pushed back into place, and the finished project.
Thanks again for the help!  Martin
1889553793_ScreenShot2020-10-25at5_44_35AM.thumb.png.92677d4488ee6cd4010b204de2a8cda5.png293100103_Photoon10-23-20at5.58PM2.jpg.dbd968c3bff7b620a5305bda36d4ee92.jpg630990038_Photoon10-23-20at6_01PM.jpg.d23206bfb4d5fabaf563117db7f72682.jpg1216863736_Photoon10-23-20at6_13PM.jpg.2b774d1e5692bbcf87f971c34996b83d.jpg1031933307_Photoon10-23-20at6.14PM2.jpg.9df590db637424818ba49de44b823cec.jpg1481356545_Photoon10-23-20at6_16PM.jpg.3e0a2cfb0f2267ec33b75c274cd5a9e6.jpg
Edited by MartinM
    • Yep, i pulled that up as well when i was looking,  there is definitely parts out there if you are prepared to go out and find them.  I watched that video years ago, I'm not so sure about probing the coil like that. If you are going to touch the coil use the side of the probe or at least shape a nice round end to it.
    • Hi and welcome to the forum.   As you are already familiar with watches the attachment you may find useful Witschi Training Course.pdf
    • I saw this listing from Australia this morning on Ebay, it might be your only option, good luck.... https://www.ebay.com/itm/145735044565?itmmeta=01HWCRFPEYDDTCXYCRX7ESQH3K&hash=item21ee7c4dd5:g:f2oAAOSwaMhmI5tq&itmprp=enc%3AAQAJAAAA4PzZAWzJj0HOwVM7Xl6qUqGIYly3BvZhzNybkxWf8GJYkKwVh0SpeZ0XYBmoZyjaboPOlJYzdY9svwhQXfR7V%2BiMApTEYFLvJcs8FxTzy1VFCBLR8ADc7V89%2B%2FYvQKdks2KDNNEqAFZN0Hni9zQG078wKL34x0eRK%2Fu843fYdH%2FVIAiOZ5%2BbOmySNdu%2Bv4cSemywC%2FWfaiI%2Fj5D3YWk2PaySdPfu7lUaMadcyhmHZM6l6NllJd1eK%2BdblkJD98pTzVuxRDne5AQaCYawls%2FaoQK9B7epV%2B87TIbD9Ulr4qdC|tkp%3ABk9SR-rnvpjjYw
    • Hi. In the picture not only does it depict that the wheel is bent but also the plate or is that due to th angle of the picture.  Already received very good advise so I will butt out.
    • welcome, sounds like you are on your way so far, you also might be able to help with gold/plated case repair for some .....
