Venus 175 hairspring alignment
niconne
Hi all,
I’m working on a Venus 175 whit several problems. Some of them on the balace side. I’ve already replaced the brocken balace staff and shortened few mm the breguet hairspring (before the service, the regulator was completely out of the index in the “fast-side” and, vibrating the spring with a hairspring vibrating tool, it was really slow). When I reinstalled the hairspring on the balance cock to check the alignment, I realized that the hairspring was completely out of center due to the misalignment of the stud screw that force the stud to rest in a wrong position (note the direction of the stud pin...).
I don’t think I can bend the hairspring at the stud level to recover this big gap.
Some suggestion to correct this issue?
Thanks
1 hour ago, Klassiker said:
Maybe a completely daft idea, but what about re-pinning with the stud turned through 180 degrees so the vee is away from the screw?
I tried this way but without vee, every time you remove and reinstall the stud, the final position after the stud screw is tightened is not accurate and this costs the bad And random positioning of the hairspring. I also tried to make a flat area in the opposite side of the vee on a spare stud using a very fine file but the final resoult was not sotisfactory.
I am impressed you have a hairspring vibrating tool?
I don't suppose we can have a picture of the balance wheel?
Bottom of the use of breguet hairspring Are hard to see I don't suppose you can take it off the bridge and show us a top view?
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
    • No thats straight out of the watch as i found it the balance wheel is almost as bad. I've never seen so much material removed.
