Unitas 6498 Click Screw... Lost
BlakeL
I've put the hairspring on hold for now since it requires extreme patience and started assembling the rest of the watch now that it is all cleaned up.  Everything was going smoothly till I realized I was missing the click screw.  Ofrei has it for around $4 but they have a minimum order of $15 and their shipping is ridiculous at $8-11 if I buy 4 screws.
Are there any other suppliers in the USA that would carry this and can I be sure that the ETA part will work on my early Unitas version?
Ofrei
Ebauches Part #5425 Click Screw for ETA 6497-1 and ETA 6498-1
-Blake
Hi Blake, I have that screw I can send it to you. PM me an address since you are almost my neighbor!
No need to pay anything. I ordered the whole set from ofrei (in blue) for the watch I "built" for my mother, so among the lot I should find what you need.
Cheers,
Bob
Cheers,
Bob
Wow, thanks.  The members on this forum always amaze me!
Excellent Blake, you are most welcome and very neat job you did there!
I'm going to try to tackle the hairspring later in the week or this weekend.  Work is busy lately and my car just died yesterday so not a good time for hobbies.
Sorry about the car Blake, hope it gets fixed soon and to your satisfaction. As for the movement, I'd love to see a picture of it ticking again. Just don't rush the hairspring thing, it is a tricky job!
Cheers,
Bob
My father in law has the Cuban hookup with a local mechanic so we'll see how well it goes.  It's the timing belt on a PT Cruiser and they're a pain to work on or I would do it myself.
The type of engine (non-interference) my car has should not cause valve damage and there was no bad sounds when it stopped running.  My old car was the opposite, it bent the valves and made a terrible noise.
I think GM cars are made that way. The car I was talking about was a chevette. Good, economic car for its time but no power anywhere: 1.8cc (carburetor) engine, no power stirring or power brakes, rear wheel traction and a 3 speed automatic transmission that took its time.... I used a horse's whip and stood on the accelerator after every red light or stop sign and still it would not "move" :) ...but it had 3 windshield wipers!! (hatchback). This was back home where there was snow (Chicago) and believe it or not, once it pulled - actually pushed -- a huge Ford Cougar out of a snow bank!
    • Dear all My first experience servicing a quartz watch after servicing as an hobby my mechanic watches for many years. This is an old Certina that was given to me by a friend, with  a ETA/ESA 9362 movement. Before service I put a new battery and the watch was working. After servicing the movement stopped working. i understand that there might be a lot of reasons for this (including the fact that I used technics and oils from mechanic movements on this one  ), but at this stage I would only need to check if the electronic module is good. Don't have a quartz tester but only a multimeter. You will see on the photos that the battery contact is broken and needs soldering. With the battery in the movement I can confirm that the electronic module had power (1.57v). Question: what basic tests can I do with a multimeter to confirm that the electronic module is good? how to check if the coil is good and if there is pulse in the electronic module? what contacts should I use to test it? (I saw some videos on you tube but was not able to find the specific test procedures for the ETA 9362). Any information to help me check if the reason for the movement to stop is on the electronic or mechanic part of the watch is much appreciated. Many thanks
    • Dear all My first experience servicing a quartz watch after servicing as an hobby my mechanic watches for many years. This is an old Certina that was given to me by a friend, with  a ETA/ESA 9362 movement. Before service I put a new battery and the watch was working. After servicing the movement stopped working. i understand that there might be a lot of reasons for this (including the fact that I used technics and oils from mechanic movements on this one 😞 ), but at this stage I would only need to check if the electronic module is good. Don't have a quartz tester but only a multimeter. You will see on the photos that the battery contact is broken and needs soldering. With the battery in the movement I can confirm that the electronic module had power (1.57v). Question: what basic tests can I do with a multimeter to confirm that the electronic module is good? how to check if the coil is good and if there is pulse in the electronic module? what contacts should I use to test it? (I saw some videos on you tube but was not able to find the specific test procedures for the ETA 9362). Any information to help me check if the reason for the movement to stop is on the electronic or mechanic part of the watch is much appreciated. Many thanks
    • I have bought without seeing inside before and have generally been luck Michael. If its a screwback case i seem to allow some leniency on the removal of it, i dont know why because I've never struggled to remove a back with very basic equipment.   If everything is inside them, then once restored and keeping time the oris could be worth 20 -30 each, I've paid a lot more Oris date pointers in the past.
    • I use a nylon bristle from a brush to run around the coils or a thin piece of copper wire, you need .1 - .15mm.
    • I actually sent a message to him on eBay asking exactly that. They all look like snap-on casebooks so should be easy enough to get the photos.
