eBay has stopped letting me list new items for sale until I sign up for there new payment method.  From what I understand they link to your bank account and if a auction goes wrong they can go into your bank account and take the money out of it. Am I miss understanding this?  Does anyone else have a problem with this?  Any help understanding the new rules would be appreciated.
I think the require your PayPal to be linked to a bank account for security.
I linked mine years ago and never had any problems (even when I was scammed).
Actually I think that as the OP mentioned is to make sure that sellers do pay their listings bills.
For buyers there is no added security in letting them know, rather the opposite.
Mine has always been tied to a credit card where they could charge me any fees.  Now they want to be able to go into my bank account without me having any control?  There are never any problems until there are problems and your fighting for 3 months to get your rent money back. Mabey I'm being paranoid but I never let anyone have access to my bank account.
I agree with you 100%. A credit card or PayPal authorization is more than enough for Ebay. I do have my utilities directly debited to a bank account but here in Europe that's common, credit cards are not universal and companies do the possible avoid their fees when possible.
That's why you open another checking account in the same bank solely for use with on-line transactions.
You can transfer in and out electronically, but the potential loss is severely limited and always in your control. They impose no limits on how much must be in the account...
The incredible (for rest of the word) feature of electronic banking in the USA is that one can initiate transfers from the receiving account as long both belong to the same person (SSN?). Doesn't seem very secure to me.
That has not been my experience.
Every  personal check has your bank account and routing number printed on it. Even with that information (on top of the name and address of the account, printed on the check), you cannot initiate a withdrawal without the consent of the account holder.
Of course you can't. But both HSBC and Citi allow to link an account from another bank which is in the same name, and initate transfers from the receiving side. End of the off topic.
On 9/25/2020 at 4:37 PM, jdm said:
...which is in the same name...
That sounds like a scammers delight to me. How do they verify you are the same Mr B Gates of Microsoft operating  the second account?
    • I have only made screws down to M1 & 14BA & I had trouble getting the slot in the centre of the head so I made a jig to help me be more accurate when cutting the slot, here is my video.
    • I would repeat what @nickelsilver says, and even more. I have at leas 10 old thread plates and I have never seen one that will cut like a normal die. I don't know if they are completely worn or have never been sharp enough, but I find them completely useless. And, for the new Indian ones, I have heard only bad things. For sure, if one tries to cut more thread on a winding stem, this hole of the plate is ruined. Further more, I have bad experience with all watch size thread dies that I could buy from the available machine  tool shops here. They could not cut normal thread even on brass rod. The size was significantly smaller and the pitch is like it should be for the claimed size... The thread shape was bad too. I will explain how I do threads. I use lathe that can cut threads and thus I can prepare perfect taps. I use milling attachment instead cutter in the tool post and so I can cut thread even on hardened rod. But I prefer to harden the rod after thread cutting and temper it only to light color change as to have the maximum hardness. Then I make a tap out of it by grinding. I prepare my dies for screw thread cutting with the taps I have prepared as described. In watchmaking, dies exist and are often used that are not cutting, but rather forming the thread. They are like nuts and don't have cutting holes and edges. This kind of dies I prepare and use. You will need soft steel plate , drill a hole in it, then cut thread, then make chamfer on one side, repeat the thread, harden. You can temper just a little or leave untempered, depending of the steel You use. Using such die is with soft steel rod (or completely annealed). Good oil is to be generously applied. The rod has to be with smaller diam than the thread size (about 0.8 - 0.9 x ), the diam is better determined by tries. The rod elongates by the thread forming too. When I have to make screws from harder material like SS, I just cut them on the lathe. You screw needs hardening and tempering to be finished as real screw.
    • You could make a guide/jig. Cut a slot in a piece of metal approx the same thickness as the screw head, then drill a hole (screw head diameter) in that slot.
    • Tried a SR920W and its completely dead after 3 weeks 🤷‍♂️
    • Thanks so much for quick replies. I got some watch repair tools ordered, and will get back with pictures once I removed the back lid and get into it 🙂
