New Addition To The Stable
Gotwatch
Thanks, guys. I'm pretty proud of this score. I have a lot of RR grades in my colection , Walthams, Hamiltons, Illinois etc. but this is my first Howard. They are few and far between on the market.
I'm sorry about the huge size. I resized them but, well, who knows what happened.
WOW,  pocket watches do not get much better than that.  I notice the regulator is on maximum retard and that this is putting an extra strain on the regulator tension spring.  The sooner you can bring the watch to time the longer that tension spring will last,  if it breaks it will be difficult job to find a replacement.
Edited by autowind
Yes, autowind, I saw that and reduced the tension until I have time to diagnose the issue. I'm in the middle of a Hamilton 922 CLA and as soon as that's done, it's on to the Howard. I'm trying to digest the 922 work to post here in the walkthrough forum. Thanks for the heads up :)
mwilkes, that's a good starting point. Will give it a go, Thanks :)
It's a runner, daz, and a strong one. I did reduce the regulator to reduce stress as suggested and it runs about +35 sec a day. I haven't had time to inspect the reason.
The bow has some brassing but other than that, she's a beauty.
    • The plate is OK, thanks. It seems the answer to my question is that this is a 'hack' & for me another reminder that in general, one won't be the first person to be tinkering with an old timepiece!. As you day, I've been fortunate to have gotten some good advice and, just as important, encouragement. I've been lucky then not to have the balance spring break as a result of my novice 'ministrations' - but I did remember to 'stroke' rather than bend per se. The clock is of sentimental value to the owner so I'm relieved to have now got it running to time with the support & encourage of forum members like yourself.
    • Thanks ww, its maybe not as much of a bodge trick that i thought it was.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  It would be nice if you told us a little about yourself.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  Can we help with what you are trying to  figure out?
    • In think you are effectively shortening the coil by shorting out damaged tracks. In my case as long as the continuity was good and the resistance not too greatly affected it should be ok .  One was on an era  movement,
