Hamilton 23 Us Military Chronometer
WillFly
This is one of my US military pocket watches - a 19 jewelled Hamilton 23 military chronometer from 1942. Grade 23 is listed as "military issue" but, as the case back has none of the usual US (or UK) military engraving and the face is very clean, I suspect it was sold after the war for non-military purposes. The movement is a one-button chronometer - you can't see the button in the pic because it's recessed into the crown. The movement is currently sticky - wound but not unwinding - so it's gone off to a friendly Amish watchmaker in upper New York State for cleaning and fettling. His name is Mahlon Shetler and he's a member of a community that doesn't use electricity - hence they need watchmakers who can deal with mechanical movements. He also specialises in all grades of US made Hamilton watches - a useful man to know!
Edited by WillFly
Thanks, Rog. One of Mahlon's specialities is making display case backs from existing backs. He cuts out the centre from the case and fits a watch crystal in its place. The back on the Hamilton 23 is slightly worn and slightly cross-threaded, so I've asked him whether it's worth getting a fresh case back and doing a display case operation on it. I haven't heard yet whether he's going ahead with this. If the watch had the usual military markings, like these below from my Hamilton GCT, then I'd keep it "as is" but, as it stands, the case back is very unattractive. Anyway - the GCT case back:
Hamilton%204992B%201941%20case%20outer.J
Edited by WillFly
A display back would be a great plus. However did you learn about "Mahlon Shetler" sometimes it's not what you know but who you know.
I have a friend, Dan - a fellow musician - in New York State, and he's a great collector of Hamilton pocket and wrist watches. Mahlon is his buddy, so I post the Hamiltons for fettling to Dan, who drives over regularly to Mahlon's to chat, shoot the breeze, and give him Hamiltons to look after. The internet's a wonderful thing!
Oh, there's no shortage of military pocket watches around. The most common are Waltham and Elgin, and the most sought after are genuine WW1 and WW2 models and makes like Jaeger Le Coultre, Lemania and Hamilton. But the number of military chronometers is far less, and this rare Hamilton might sell for around £600-£700 in good condition - but I'll never sell mine! I bought it at an online auction a few years ago - can't remember what I paid for it, but I think it was in the £200 region.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
    • I think what peter means oh is once he has fitted the hands and  checked for  alignment if them and that they dont foul, how does he then hold the movement to remove the stem in order to case up. The dial cannot be laid on a cushion or in a movement holder as the hands will get damaged. This can be quite tricky for a beginner, what i do is  to stand the movement on edge on a rubber pad so it doesn't slip. Hold the top edge with one finger then my dominant hand uses 3 fingers to press the stem release and flick out the stem. See below peter, leave off the second hand as this is the longest and gets caught the most, then fit it once the stem is out. Alternatively place the movement in one of the cup style holders, i imagine this is what they are designed for. They only touch the very edge of the dial.
    • Yes I understand that. What I’m asking is, after the hands have been fitted, it’s been checked that the hands do not touch etc. then I need to remove the stem to fit the movement in the case. I have the push type, I need to turn it upside down and push the setting lever post and pull the stem out. But of course the dial and hands are in place and I have a glossy dial with lume dots and I do not want to cause any damage while it’s upside down pushing on the post of the setting lever.
    • You have answered your own question. You just push the setting lever nipple in or if its the screw in type unscrew it a little. You should always remove any hands and the dial before putting it in your movement holder.
    • Did the old battery leak and damaged the circuit board? Can you post some photos of where the buttons make contact on the circuit board.  Try cleaning the gold fingers on the board with alcohol and also the conductive rubber strips behind the LCD display panel.
