Hello,
   I've been playing with watches at a very basic level for a couple of years.  Changing the batteries, replacing crystals, that sort of thing.  I have a bit of background at working with small stuff   - electronics fabrication.    That hobby gifted me with a nice stereo microscope.  Well, actually it was the local tech fleamarket.   I'm ready to step it up a little....
...Back around 1983, I bought my wife a nice Seiko lady's watch for her birthday.    I seem to remember paying $250 for it.  ( $650 in 2020 dollars ).   It was a 7n83 with a diamond at the 12 o'clock position.    Over the years, I have changed the battery when it needed it.  Last year, I replaced the scratched mineral crystal with a sapphire one.    When the bracelet broke I searched for a replacement - and found that the easiest and most cost effective thing was to buy parts watches on Ebay.
Now, the battery just doesn't last, and the second hand goes bump-bump instead of bump.  I suspect the mechanism is tired and needs cleaning and lubrication.  A daunting task, given how small the thing is.  However - a brand new mechanism is just $20 and change at Esslinger's.  It's in hand.
To remove and replace the mechanism - and keep the dial ( with the diamond ), I have to remove and replace the hands.  So I got a Bergeon hands puller to get them off and a set of hollow pins for putting them back on.  I have successfully done this on one of my parts watches.
My question is:  Are new watch movements shipped with a standard hands position?  I'd rather put them on correctly rather than try to horse them around once they're pushed on.  Don't want to put any more wear on the holes than necessary.  Can't seem to find anything about this anywhere.  I sent an email to Esslinger's but they haven't answered.  Thanks in advance,
            Jerry K
Hello and welcome to the forum Jerry K, As Nucejoe remarked it is best to find the caliber number and make when ordering a replacement.  They usually come as a basic movement less dial and hands which you have to swap over to the new one   can you post a picture of the movement as it helps.   thanks
1 hour ago, jerryk said:
Hello,
            Jerry K
Update:  More search suggests that there is no standard position - you just twirl the adjustment till the date changes, and that's midnight.
    • @oldhippy - wishing you all the very best of recoveries
    • Looks like the kind of message that occurs when there are routing issues between your local network and the remote server the site is living on - there can sometimes be 20 or 30 hops and when there are issues some of those hops become unavailable temporarily for some people but for others where there is a different path being used the issues are not manifest. Another explanation, and this used to happen to me a lot with my ISP, is using the ISP DNS servers on your device or router sometimes is not as robust as changing to a public service such as 1.1.1.1 or similar. I was having a terrible time watching Youtube a while back - changed the DNS on my Apple TV to use 1.1.1.1 and problem solved. However, these issues tend to resolve themselves fairly quickly.
    • As mentioned by the other members, it’s a dismantle job clean and inspect the solder joints. It’s an older generation using the paxolin pcb  not the glass fiber ones.
    • Hi  in regard to your questions,   The springs should ideally removed from the barrel but to do this you need a mainspring winder that are quite expensive for a one off. Or you c a make your own see Google “ joes mainspring winder”. I have made two and they work well, you will also have to source some tube for the retainers. the gathering pallet cann be removed using levers ( mini crow bars) again I made my own no problem. the case can be glued using evostick wood glue but bind the case together to close the crack. When solid you can use wax sticks (used for furniture) melted and rubbed in to cover any blemish left. best to clean the case and then use bees wax to polish, a bit of elbow grease needed  do not clean the dial with anything other than warm water and a couple of drops of mild soap. Try on an inconspicuous part first. There is a product called MILIPUTTY in various colours on eBay that can be used on cracked enamel dials depending on how bad it is .
    • I was wondering because of the alum idea.
