Good morning all
I recently purchased this Oyster Lipton and was wondering if anyone could shed any light on the dial for me. Personally I have no expertise in restoring dials and wouldn’t like to give it a go myself as I don’t want to make it worse. Would a dial in this state be able to be cleaned up by a professional restorer or would the dial have to be completely refinished? And if so is there anyone who you could recommend. Any input would be greatly appreciated, cheers guys
Hi   with a dial in that state I would be inclined to take it out of its case and have a look  at the condition of the watch and under the dial at the front plate.  The stain looks like a rusty water mark coming through the dial. If the damage is only surface deep it would be able to be restored but at a cost.  Diy cleaning may lessen the effect but it wouldnt be permanent.
If you do open it be aware that as the watch was manufactured in the 1940's (apparently for the Canadian market) the lume WILL BE RADIUM, so take the appropriate care....................
I dont think that is rust, under the numerics 1-12 were the blur is there should be the numbers 13-24.
Somehow these have floaten out, probably residues from a previous attemt to fix the dial.
To get this in a good shape you need to leave it to a professional dial restorer who can take that ink away and print new numbers.
Under this hood should be a Rolex Cal. 59, a modified FHF30.
Cheers for all the input guys, I will be talking the watch to a specialist as this is far beyond my capabilities. Once I have the dial back I will post some pictures [emoji106]
 restored dials decrease the value for many vintage watches such as Rolex, Omega and many other top brands.  Collectors like to see the age and imperfections that develop over time as these make each watch unique in its own way.  Have the movement serviced, and any debris removed from the dials and hands.
here is one article that supports this - https://www.wpdiamonds.com/watch-damage-affect-resale-value/#:~:text=Older watches with a patina,the authenticity of the watch.
Edited by JerseyMo
I think the most agrees with this and as a collector myself I would prefer a dial with Normal aging, patina and imperfections which appeared by natural causes.
But sometimes the imperfections occur when someone just wanted to “clean off” the dial a bit.
This often results in a much lighter dial than expected and with print or varnish gone. In this case it will not preserve the price I think.
A small example of what I mean with patina and imperfections can be seen to the left.
This is just my opinion and I think the most professional restorers are gentle and will preserve the dial in a preferred condition.
As a collector of many clocks  they are repaired and tidied up but no restoration. They gathered all the imperfections in life and are an intrinsic part of the Clock/Watch,  its history and to me removing all that to achieve an almost as new clock / watch is sacrilidge, just my opinion there will be others who differ for sure.  All the clocks I repair for others are th same and most clients want it preserved as it is. Some are over 100 Yo you dont live to that age without a few bruises, If I live that long . I have done the 3 score and 10 and still running on reduced power.
Interesting, when you talk about the price being preserved are you saying having the dial redone will not affect the price? And I agree these markings to the dial do not look natural to me they either.
why does it matter if the cause is natural or not?   Here is one of my favorite watches When it came in there was no crystal, missing hands and very rusted movement.  Now it shows the scars of time just like me.  Faded some and took some work to get ticking again.  It cost me less than one dollar to purchase and only $45 to have it fully serviced.  The mainspring arbor was rusted and needed replacement.  it cost me $45.  Of course it is all a matter of preferences.
    • Hello from Boston David…
    • Sorry @nickelsilver, I'm just seeing this now.  It is a standard metric screw plate. I followed the suggestion of doing the thread cutting in a pin vise.  It took me forever because the piece is so delicate that I cut and cleared chips very frequently.  But eventually I did get it.  Not pretty, but I got it; the first thing I ever successfully made on the lathe. I cut the screw slot with a jewelers saw.  How can I ensure that the slot is centered on the screw head?
    • Hello, My name is David and I’m a vintage watch collector/ wanna be hobbyist watchmaker from France. I really want to progress into my watch repairing hobby. For now, I’m only having fun servicing my own watches and spare movements, simple small 3 hands from the 50s (Omega, eterna…) Learning step by step or at least trying to 🙂
    • More setbacks and successes...  After letting the watch run in (but before I fixed the BE) a chunk of the radium lume fell off one of the hands and pulverized leaving radioactive dust all over the dial 😞 ☢️ ☠️ So before I could continue further I decided I would remove the radium lume.  I have removed radium lume from hands before where it was already starting to flake away but this time I had to work out what I was going to do with debris on the dial.  I decided that getting everything under water and removing all the lume was probably the best way to go. So here is what I did... I put an essence jar I use for cleaning parts and filled it with water and put it into a big ziplock bag along with the tools I would need - a sharpened piece of pegwood and  a 0.80mm screwdriver  -  I put on a pair of nitrile gloves and a covid style mask and then opened the back of the watch. Now with the back off the watch I could do the rest inside the bag.  I removed the watch from the case and removed the hands from the dial (through the bag) and then undid the dial screws and removed the dial from the movement.  I then put the hands and the dial and the watch case into the water and removed the movement from the bag.  Carefully and slowly with one hand in the bag and one hand trying to poke and hold stuff through the bag I gently rubbed away the lume from the dial and hands with the pegwood. I then took the parts out of the water and removed the jar from the bag (leaving the parts still in the bag) - with the majority of the dangerous stuff now in the water I disposed of this (down the toilet) and gave the jar a good rinse in running water before refilling it and returning it to the bag where I gave all the parts another rinse in the new water.  I then took the parts and put the geiger counter over the top of them and looked at them carefully under UV light to see if there were any flakes still hanging on. I dried everything with some kitchen towel. Once I was finished will all that I remved the parts from then removed the gloves and put them in the bag with the paper towels and the pegwood and thew the bag in the household waste. Finally I gave the dial, hands and case another rinse in the sink under running water.  I didn't bother following up with a rinse in distilled water water because the water here is pretty clear of limescale etc and I find it doesn't mark! So here are the results of my weekends work! Timegrapher dial down (dial up is almost the same) The fixed shock setting New crystal - and lume removed from dial and hands
