Dear All,
Any experienced maker could enlighten me on the secrets of parting 316 Stainless Steel?
I usually hate parting big pieces on the lathe, but so far Brass and Steel could be handled. But this 44mm diameter 316 SS piece is challenging me.
Tool has been shaped to 8 degrees of back rake and end relief, has side clearance and is aligned to the centre. Best speed calculated at 115-135 feet/minute equalling 330 RPM.
But the parting tool looses every time.
All I manage to make are extremely dangerous micro stainless steel needles, and dented tools. The chattering is horrible.
Is it possible that I unintentionally hardened the blank while trying to cut, and now it's harder? Should I use a lot of coolant?
Best regards,
Marcos
What lathe are you using? 316 (and 316L, most common for case parts) is usually ok as far as stainless goes, but is going to be more difficult than a typical steel for sure.
When I part a piece that size in my lathe (Schaublin 102), I do everything possible to maximize rigidity. Cross slide is positioned so the tool is over a dovetail, not hanging out. Tool retracted into holder as far as possible. I use two parting tools, one quite stubby, maybe 15mm stickout, and another longer to take over from there. I'll even snug up the gibs for a little more rigidity.
Use a good cutting oil, preferably one for stainless or difficult metals.
330rpm would be too fast for me. I kick mine into backgear and inch up the speed until I get chatter, then back off. With a parting tool in 316 you may or may not get a real chip, depending on the foundry that made it and even the batch. If you do get a chip it often doesn't want to break and you have nice long moving razors around the workpiece- resist all temptation to grab it and pull it out of the way! Use pliers. And interrupt the cut to break it.
If you're getting chatter you either need to increase the feed or reduce the speed. On a Monarch 10EE or Schaublin 150 or Weiler yeah go ahead and increase the feed. On a smaller machine you can only reduce speed.
316 will work harden in 1 revolution. Your tool has to be SHARP. Stop and touch it up as often as you have to.
Sometimes once chatter has started it won't go away no matter how you mess with speed and feed, in really crap chatter situations I might take a few strokes with a hacksaw in the groove to knock off the chatter ridges on the part. This can remove a work hardened skin too.
Are you using carbide or HSS?
Together with the good advice by master nickelsiver, I repeat the fundamental question, what lathe are you using? What you're attempting to do requires a pretty sizable lathe,  a very minimum of 1Kw motor perhaps. And from your writing I gather you're using HSS, but for hard metals you really need indexable tools.
Thank you Nickelsilver.
I am using a BV-20 , 1/2CV, six-speed lathe.
Tools used: HSS 12% and 50% cobalt.
I will try to get rid of the ridges and cut again, with the slower speeds.
With a 370W motor, it should be a geared headstock type? However parting 44mm is hard work even for lathes much bigger than your.
Quote
Definitely an hard proposition.
Quote
Check what the carriage does. Even when fully locked it may still move a little. When it does, all bets are off, chatter comes, the cutting point wanders, machinist swears and the suppliers get a chance to sell.
Below, good machinist receives 316 work just to be parted off
Edited by jdm
Ok, that's not a baby lathe, but not one known for its rigidity. HSS is ok but you will need to sharpen often.
Stickout from the chuck needs to be as small as possible. For something like this I use my 4 jaw chuck; for one the gripping power is greater than a 3 jaw, and on my machine it sits about a centimeter closer to the headstock- that cm makes a world of difference.
You can think of overhang (stickout) as decreasing rigidity as a square; if you have 15mm and that gives you x rigidity, then go to 30mm it not half as rigid, it's way way less rigid. So if your raw stock is 50mm and you need a 15mm slice, stick 16mm in your chuck, and part off right next to the jaws. Then face it off to thickness.
I’m sure this may be considered a faux pas to some, but for a rough cut on larger items, I sometimes mark a groove with my graver and then cut with with a piercing saw.
That's 100% approved A-OK especially when needing to part something that's challenging the rigidity of a machine. If on a larger lathe best to put a block of wood under the cut or the saw can surprise you when it gets through and nick the bed (I do the saw trick with the lathe running). Just remember to reverse the spindle direction id using a jeweler's saw where the cut direction is opposite.
Oh, I certainly meant with the lathe running! Works a treat for a quick job. Make sure to move the saw blade to prevent heat build-up too.
Trivia bit, japanese woodsaws are opposite too. The reason given is that their trade was done mosty done outside the shop, so work was held without a vise.
That’s very tempting, hahaha. I feel ashamed of letting people hear the squealing from the shop..
I actually cut and welded my toolholder so I can cut using reverse rotation. That’s why I could not post anything in answer of your kind tips!
I may seem like those people who take more pleasure in cleaning the desk than getting the work done
I will bolt the lathe to a granite bed and then test this. Got enough of low standard jobs already..
thank you for the tip!!
Edited by marcoskaiser
Incomplete
Thank you Nickelsilver, Rodabod and Jdm, It was a success! First getting rid of the part already started and full of bumps with a hacksaw took only a few minutes. Not difficult, and the saw came back still good, not blunt... I will adopt this approach whenever possible.
picture 1
Then overcoming the lack of rigidity by working close to the chuck, with minimum overhang worked fine. Good chips, and a nice sound of metal actually being cut.. finally.
Funny thing, and in accordance to what nickelsilver said, the recommendation to cut stainless at 115-135 feet per minute of surface speed does not apply to parting, and with a much lower speed the parting was easier. I used 140 RPM and it was fine.
picture 2. Nice chips
Then to the end. At some point the tool got stuck, and had to be resharpened. I was going straight, without any lateral clearance, encouraged by the smooth operation. Apart from this, a good experience. I finished the blank with a hacksaw, but only because the tool could be off-center after resharpening and was cutting less towards the end.
picture 3.
With these tips, I guess other people will find easier to part 316L.
The lathe is still waiting for the granite bed. Eventually I will bolt it better.
Thank you again for the help!
I'm glad it worked out!
Couple of more parting observations. The tool should be on center, but if it's not, you want to be below rather than above. If above center, with the flex of the machine and slides it will go down, which effectively makes you cut depth double or close to it. This is where tools break, parts pull out of chucks, and in extreme cases with enough power the tool post rips out the top of the cross slide. If the tool is lower and flex decreases the cut.
And, when parting a piece that doesn't have a center hole, especially larger work like this (all things considered), it's very common to finish off the last bit with a saw. With a bit of care you won't even mark the part.
    • Sorry @nickelsilver, I'm just seeing this now.  It is a standard metric screw plate. I followed the suggestion of doing the thread cutting in a pin vise.  It took me forever because the piece is so delicate that I cut and cleared chips very frequently.  But eventually I did get it.  Not pretty, but I got it; the first thing I ever successfully made on the lathe. I cut the screw slot with a jewelers saw.  How can I ensure that the slot is centered on the screw head?
    • Hello, My name is David and I’m a vintage watch collector/ wanna be hobbyist watchmaker from France. I really want to progress into my watch repairing hobby. For now, I’m only having fun servicing my own watches and spare movements, simple small 3 hands from the 50s (Omega, eterna…) Learning step by step or at least trying to 🙂
    • More setbacks and successes...  After letting the watch run in (but before I fixed the BE) a chunk of the radium lume fell off one of the hands and pulverized leaving radioactive dust all over the dial 😞 ☢️ ☠️ So before I could continue further I decided I would remove the radium lume.  I have removed radium lume from hands before where it was already starting to flake away but this time I had to work out what I was going to do with debris on the dial.  I decided that getting everything under water and removing all the lume was probably the best way to go. So here is what I did... I put an essence jar I use for cleaning parts and filled it with water and put it into a big ziplock bag along with the tools I would need - a sharpened piece of pegwood and  a 0.80mm screwdriver  -  I put on a pair of nitrile gloves and a covid style mask and then opened the back of the watch. Now with the back off the watch I could do the rest inside the bag.  I removed the watch from the case and removed the hands from the dial (through the bag) and then undid the dial screws and removed the dial from the movement.  I then put the hands and the dial and the watch case into the water and removed the movement from the bag.  Carefully and slowly with one hand in the bag and one hand trying to poke and hold stuff through the bag I gently rubbed away the lume from the dial and hands with the pegwood. I then took the parts out of the water and removed the jar from the bag (leaving the parts still in the bag) - with the majority of the dangerous stuff now in the water I disposed of this (down the toilet) and gave the jar a good rinse in running water before refilling it and returning it to the bag where I gave all the parts another rinse in the new water.  I then took the parts and put the geiger counter over the top of them and looked at them carefully under UV light to see if there were any flakes still hanging on. I dried everything with some kitchen towel. Once I was finished will all that I remved the parts from then removed the gloves and put them in the bag with the paper towels and the pegwood and thew the bag in the household waste. Finally I gave the dial, hands and case another rinse in the sink under running water.  I didn't bother following up with a rinse in distilled water water because the water here is pretty clear of limescale etc and I find it doesn't mark! So here are the results of my weekends work! Timegrapher dial down (dial up is almost the same) The fixed shock setting New crystal - and lume removed from dial and hands
    • Hi and welcome! I'm new here too—greetings from Leicester, UK.
