Crystal Polishing
Hey all,
I'm working on a Citizen, and the case is scratched to high heck and back. I gave it a clean and it looks significantly better, but the crystal is scratched badly, and I wanted to see if the scratches can be polished out first before considering replacing the crystal. I bought a "polishing pen", but I don't know what compounds to use when polishing the crystal, or even the polishing procedures in general. The case may have to wait because it is brushed stainless, and I don't own a buff wheel, and it's another expense, so for now whatever can be done with the pen is preferable.
I pick this up on Amazon and used my dremel tool worked fine for what I needed but the watch crystal I used it on was not scratched to badly. I have watch some used very fine sand paper to start then switch to a polishing compound.
https://www.amazon.com/Polywatch-Plastic-Crystal-Polisher-Polishing/dp/B07RYPG96T/ref=sr_1_4?dchild=1&keywords=watch+crystal+polishing+kit&qid=1595957048&sr=8-4
the problem with the description of your watch here is it doesn't tell us something? The problem with watch crystals are the made out of a variety of substances. then not just variety of substances brew variety of shapes some of which are hard to polish.
so classically anything other than plastic typically never got polished. Although glass domed crystals can be polished if you have access to lapidary equipment because normal glass isn't that hard. A lot of the watch companies use harder or different types of glass which is tough for the regular glass and they are a lot harder to polished if you can do it all and if they get super heavy scratches getting those out is problematic. Or there's things like sapphire crystals which are supposed to never scratch you have to use diamond compound if they ever got scratched.
so classically plastic crystals are typically all you can polish. Usually the buffing wheels are bigger than what you have on your drum old-school usually several inches in diameter the bigger the better up to a point. It did not careful you get carried away you can actually burn the crystal and make things much worse.
So for instance other substances to use since we were looking at Amazon
https://www.amazon.com/Plastic-Crystal-Scratch-Remover-Polish/dp/B000RAYKMC/ref=sr_1_3?crid=24G92U3LL97MY&dchild=1&keywords=watch+crystal+polishing+compound&qid=1595960541&sprefix=watch+crystal+polishing%2Caps%2C222&sr=8-3
https://www.amazon.com/Jewelers-Supermarket-Crystal-Polishing-Compound/dp/B00634K1PG/ref=sr_1_5?crid=24G92U3LL97MY&dchild=1&keywords=watch+crystal+polishing+compound&qid=1595960773&sprefix=watch+crystal+polishing%2Caps%2C222&sr=8-5
then they here's the stuff that I'm familiar with notice the second line that I'm quoting "Press gently to prevent burning the plastic crystal" it can a really do a good job but if you have super heavy scratch is cracks and other stuff there is not much you can do.
http://www.julesborel.com/products/crystals-crystal-tools-crystal-polishing/Plastic-Buffing-Compound
Have a read below. But if it's a flat round replace it for less than $1.
Its  down to economics and time,  any watch glass can be polished if as John725 says you have the equiptment,  and as jdm remarked the glass can be changed for around a Dollar, a bit more if you include a glass press .  Polishing machines and compounds can run into Hundreds of Dollars.  So the way to go is replacement.  Plastic/acrylic "glasses" can be polished by hand using propriety compounds easily enough.
Actuality it's not so bad. Check Foredom TM-2 on AliX for about $50. Add 10 more for few felt wheels, compounds and diamond paste. Furthermore the machine can be upgraded with various accessories. Definitely a recommend purchase.
    • your balance wheel looks interesting in the watch and because it's at an angle it's changing things a little bit. in other words they hairspring is not centered between the regulator pin in the boot and I also noticed your terminal curve is lacking apparently by design? Because if you look in the second image you'll notice yes there's a terminal curve but not as aggressive a one as you normally see on watches at least most watches.   then in all of your images it looks like the boot isn't quite back where it's supposed to be? out of curiosity how did you remove your balance complete and clear the regulator pin? then just in case you weren't aware it rotates out of the way so you can remove the balance complete without bending the pin. Then it's rotated back exactly 90° and yours looks like it's off by just a little bit in the original image and I'm assuming that you just been the pin out of the way? it's always interesting in horology is the variations in the things. Like the image I have above does have a terminal curve but not the most aggressive and yours is even less but that is the way the watch was made. Then the spacing between the regulator pin in the boot should be relatively small basically if you had two pieces of the thickness of your hairspring that's how much space should be there like in this image. But oftentimes watch manufacturers do not necessarily follow the rules
    • Yep i can see where you're going with that one Rich.  Sooo now that I've frightened the OP into submission 😁. Chief i do apologise for some reason unbeknown to myself I'm in a happy silly mood. So seriously to identify the movement lets have a look at the dial side, learning this part is straightforward, just need a little logic and something called the # BESTFIT BOOKS # . Or the other non American equivalents.
    • I can definitely see elephant and aardvark and possibly some sort of bird with a large beak 🤣 anyway I'll have a go of getting it flipped over tonight and send some pics
    • A Schild movements often have left handed crown screws. A pic of the keyless works would help identify it, and the size of the movement. Looks like someone has had a, not very subtle, attempt to decrease play in the centre wheel. And the hairspring looks like it needs some work. From the scratches on the bridges, it looks like it was last serviced by a drunken baboon, but it's a good movement to practice on. Good luck
