Hello, I'm back with yet another question. This time it's regarding a cleaning solution I've used a couple of times.
In my cleaning process I start with mixing the solution and water to the right ratio and then pour it into the ultrasonic cleaner. Then I run the cleaner for 30 minutes or so. Once they're done I dip them in water and then in isopropanol.
After the cleaning the parts come out as super shiny. Except for a few. Usually the setting lever and pivots on the trainwheels come out as dark and when touching them with my nail for example it feels rough.
Is there something wrong with my cleaning solution? If so, is there any recommendations for a cheap cleaning solution?
Does this affect performance of the watch?
Thank you very much for your responses.
(Can't visit the page for the item, so this screenshot will have to do)
Is it possible you are causing some sort of electrolysis which is playing the steel parts?
This certainly happens if you use ammoniated solutions and aluminium.
Wouldn't think so.. The jar i put the parts and solution in is of glass. Maybe it reacts with the mesh cage for the smaller parts? Not sure what they are made of. Other than that I really don't know. Unless there is something in the solution..?
30 minutes in the ultrasonic sounds a bit too long. Ultrasonic cleaners can be very damaging.
You can try an experiment. Just take a small piece of aluminum foil hold it with your fingers and just dip it in the bath and run it for 1 minute, try not to touch the sides or bottom of the tank. Now remove the foil and inspect it. It should be peppered with a lot of holes. This is how we test an ultrasonic bath to see if the transducers are working properly. And also to check for and "dead" spots where there is no ultrasonic energy.
I normally put my parts in the solution and run it for a couple of minutes. Then let it soak for maybe 10 minutes and run it for another 2 minutes. This way, I minimize the cavitation damage to the surface of the parts.
I had a similar gaffe recently. I did 10 minutes X3 cycles (clean, rinse 1, rinse 2) and stripped the nickel plating off the majority of the main plate (but nothing else surprisingly). Shocked the hell out of me, because nickel on brass should definitely be hard enough to not have issues. For the most recent cleaning, I did 3 minutes for each cycle, and that seems to have been plenty. I'll try two next, then one to see where the curve falls. It definitely seems like more makes sense, and there's nothing really out there in the literature about how long to use an ultrasonic cleaner (at least not that I've seen). This forum is great for hammering out those little details...
the company that makes your cleaning fluid is very unhelpful as there is no material safety sheets or chemical properties of their cleaning fluid other than vague terms. But it does comment that makes metals bright shiny which makes me suspicious there's probably ammonia in the cleaning fluid. Ammonia is really wonderful for cleaning watch parts it is the substance that makes the parts bright and shiny. But as spectre6000 and I have found out even using cleaning fluid specifically designed for cleaning watch parts a little cleaning is good a lot of cleaning is bad and throw in some heat that would be very bad. So even commercial watch cleaning fluids are very time-limited because at a certain point in time you go past cleaning and you have the possibilities of cleaning the metal right off the watch parts and putting it in solution..
ttps://www.carbusonic.co.uk/ULTRASONIC-CLEANING-FLUID-JEWELLERY-JEWELRY-WATCHES-TATTOO-DENTAL
you have a unknown water-based solution and your cleaning wheels which are made out of brass and steel which definitely could form a undesirable electrolysis situation.
the answer to his or something wrong with your cleaning fluid yes it's not designed to clean watch parts. But if you insist on using it try five minutes or find something to practice with it's disposable and see how long it go before bad things happen. then for the performance issue if your pivots are feeling rough that would be undesirable.
Ok, thank you John. I thougt you needed som sort of electricity for a reduction to occur. I'll check it out in the weekend.
    • Sorry @nickelsilver, I'm just seeing this now.  It is a standard metric screw plate. I followed the suggestion of doing the thread cutting in a pin vise.  It took me forever because the piece is so delicate that I cut and cleared chips very frequently.  But eventually I did get it.  Not pretty, but I got it; the first thing I ever successfully made on the lathe. I cut the screw slot with a jewelers saw.  How can I ensure that the slot is centered on the screw head?
    • Hello, My name is David and I’m a vintage watch collector/ wanna be hobbyist watchmaker from France. I really want to progress into my watch repairing hobby. For now, I’m only having fun servicing my own watches and spare movements, simple small 3 hands from the 50s (Omega, eterna…) Learning step by step or at least trying to 🙂
    • More setbacks and successes...  After letting the watch run in (but before I fixed the BE) a chunk of the radium lume fell off one of the hands and pulverized leaving radioactive dust all over the dial 😞 ☢️ ☠️ So before I could continue further I decided I would remove the radium lume.  I have removed radium lume from hands before where it was already starting to flake away but this time I had to work out what I was going to do with debris on the dial.  I decided that getting everything under water and removing all the lume was probably the best way to go. So here is what I did... I put an essence jar I use for cleaning parts and filled it with water and put it into a big ziplock bag along with the tools I would need - a sharpened piece of pegwood and  a 0.80mm screwdriver  -  I put on a pair of nitrile gloves and a covid style mask and then opened the back of the watch. Now with the back off the watch I could do the rest inside the bag.  I removed the watch from the case and removed the hands from the dial (through the bag) and then undid the dial screws and removed the dial from the movement.  I then put the hands and the dial and the watch case into the water and removed the movement from the bag.  Carefully and slowly with one hand in the bag and one hand trying to poke and hold stuff through the bag I gently rubbed away the lume from the dial and hands with the pegwood. I then took the parts out of the water and removed the jar from the bag (leaving the parts still in the bag) - with the majority of the dangerous stuff now in the water I disposed of this (down the toilet) and gave the jar a good rinse in running water before refilling it and returning it to the bag where I gave all the parts another rinse in the new water.  I then took the parts and put the geiger counter over the top of them and looked at them carefully under UV light to see if there were any flakes still hanging on. I dried everything with some kitchen towel. Once I was finished will all that I remved the parts from then removed the gloves and put them in the bag with the paper towels and the pegwood and thew the bag in the household waste. Finally I gave the dial, hands and case another rinse in the sink under running water.  I didn't bother following up with a rinse in distilled water water because the water here is pretty clear of limescale etc and I find it doesn't mark! So here are the results of my weekends work! Timegrapher dial down (dial up is almost the same) The fixed shock setting New crystal - and lume removed from dial and hands
    • Hi and welcome! I'm new here too—greetings from Leicester, UK.
