ok.  I need larger diamter watch jewels and looks like odd sizes.
I need
21/120, 31/160 at least.
I go on Cousins and they are listed as obsolete and otto frei and jules borel here in the usa dont have them either.
Who else sells watch jewels?  What does one do when they cannot find the correct jewel to fit the pivot??  Wait and watch on ebay?
I do keep a selection of jewels, but sometimes do have to order them.
The last time I ordered, I had to get one size larger for the outer diameter and then broach to fit. Sometimes that can be a good thing as the old hole may not grip tightly enough on the “same” size jewel as the original.
Standard Seitz jewels are sized in 0.01mm hole increments up to 0.20mm, from there they go in 0.02mm increments. In industry makers would order jewels from specialist makers, to whatever size they wanted. In general the outer diameters would correspond to normal 0.10mm increments but the hole sizes could be anything- one common size I see is a 0.25mm hole, which isn't in the Seitz offering. What are your actual pivot sizes? Thankfully, at 0.20mm and up an extra 0.01mm of wiggle room usually doesn't affect performance. Do any of the suppliers have a 22/120 and 32/160?
I simply gave up.  I ordered one size up as you suggested @nickelsilver a while back from jules borel but the powers that be have ruined our USA post office and they havent shown up yet 6 weeks later.  So i put the darn thing back together with loose pivot holes and its working ok.  Its actually running fast.  Ill have to demagnetize and see if that helps.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
