  On 9/2/2024 at 8:54 PM, AndyHull said:
For 0.99p who (other than every sane person on ebay obviously) could possibly resist.
A non working Newmark with fixed lugs, probably from the late fifties or early sixties.
Expand
Strange how the dial looks twisted but the 3 lines up with the crown.
I'm presuming the case back is what lines up the movement.
Expand
From memory I think you are correct, but it might also be a slight optical illusion as the pictures are taken from an odd angle. I'll confirm the situation when it arrives.
Edited by AndyHull
  On 9/3/2024 at 12:26 AM, rehajm said:
A sharp looking dial but does it appear to be aligned perfectly with the crown but crooked in the case 😕?
Expand
What can one expect for .99p .
 Imagine 10000 from now, our grand grand..... kids, will say  "   look !     this is some sort of mechanical time keeper, our grand grand... fathers used for being on time.  The other, would say ,
oh really !!   Let me see , how did it work?
 Another one jumps in and  says,
" thats nothing man"
then shows pictures of cows and says, they used to eat this creatures , called them cow / hamburger or something.
Next one declares    "   yach  ,I wouldn't swap my cock roach powdered protein sandwich with tons of that stuff" .
The way we are carrying on at the moment, its more likely that the highly evolved cockroaches will be having this conversation after we have nuked ourselves into the history books. 😋
Expand
Haha,
  On serious side,  I don't think there be a nuke attack,  just a tactical use at worst, but you are right, one never knows.
Unfortunately, us homo sapiens have throughout history proven our stupidly despite all smarts.
  On 9/3/2024 at 2:42 PM, Nucejoe said:
Haha,
Expand
“Two things are infinite, the universe and human stupidity, and I'm not sure about the universe.”
― Albert Einstein (allegedly).
  On 6/19/2024 at 7:55 AM, AndyHull said:
These little "beauties" are on their way.
Who could resist three for a quid?
Most sane and sensible people I suspect.
Expand
The alarmingly cheap replacement quartz mechanism for the Rotary in this bunch arrived the other day.
As I suspected, it is a Chinese clone of the original movement, which meant that not only did I have to replace the movement, but I had to cut and fit the stem that came with the replacement, as it differed markedly from the original.
Having said that, it works, came with a free battery, and looks identical once fitted, so all three of this job lot are now working perfectly and looking almost like new.
Edited by AndyHull
Just for completeness here is the 99p lot ticking away nicely. I could have picked a better time to take the shot as the date is just starting to change on the Rotary. Oddly it takes forever but the number finally clicks into place almost exactly at midnight. I may have a play with this to move it forward a bit, but currently I think it is fine the way it is.
Edited by AndyHull
Expand
@AndyGSi Correct. There is nothing to stop you fitting the mechanism in whatever position amuses you. Obviously it is *meant* to look like this.
 I now have it cleaned and running. It needs a crystal, but I may have another crack at removing some more of the scratches. I also need to dig through my stash and see if I have a suitable 16mm fixed lug strap. I have the original one steeping in some detergent and disinfectant, but it is a little tired and worn, so I don't think it will be recoverable. I may save the buckle and indulge in a little leather work to fabricate a replacement.
A "Siro" pin lever nickel cased "trench watch" for 99 pence. This most likely has radium on the dial, so I'll need to be a little careful with the cleaning.
The case looks in reasonable condition, except for some oxidation on the front.
  • Like 5
  On 8/31/2024 at 8:57 AM, AndyHull said:
A 1972 Timex is on its way. Listed as "not working" (no surprise there) and "automatic" (it isn't).
It looks to be in reasonable condition, but pretty filthy (also no surprise).
This one came in at exactly £4.04 plus postage.
Expand
Cleaned and running.
I picked this up at the vintage fair on Sunday for $5. Ineresting little 32mm watch. Seems to be an older size 0 but with production date of.May 1904. With Sir Wm Pitt on the dial and bridge maybe made for British but made to.look like an American pocket watch conversion? The clasp on bracelet say sturdy with a patent date of 1928. Lugs definately a later addition.
Was all gunked up so stripped, cleaned oiled and reassembled. Will need to work with the hairspring but everything is there and working.
Added new crystal. DSCN61072.thumb.JPG.cde40d04e43ef5128dddda9d23541e0f.JPGDSCN61052.thumb.JPG.e3049e563be3af7a00904bced76c5e27.JPGDSCN61132.thumb.JPG.4b6f18e9c1e460c3aa0084b822734560.JPGDSCN61142.thumb.JPG.171b09696598f4b879cda4171b66a93b.JPG
Edited by Razz
