3 hours ago, RichardHarris123 said:
This. Looked it up, it's seaside grade but the case is railway grade, I think.  Look at the cutout on the front of the case, that was for the setting lever.
Oops. Not seaside grade, wrong company.  But interesting case.
You not having much luck with hairsprings Rich. This one looks like it needs some tlc. Good to have you back btw. Nice to have some Yorkshire in my corner.
Plenty more to come.
A couple of mystery watches on their way. They come with some random LCD modules too. The whole job lot cost a pound.
The LCD above may be a Seiko but has lost its "glass" which is going to be somewhat difficult to source, so I may get creative with this.
The LED is a complete mystery, but the case looks to be in good condition and possibly stainless steel rather than chromed.
Here are the rest of the motley crew.
Edited by AndyHull
My first 404 watch build, bought a batch of 20 for £57.00 (average of £2.85 each):
Joblot-Of-20-Antique-Vintage-Gents-Watches-Rotary-Etc-Spares-Repair-Steampunk-eBay.png
Here are the before and after pictures. All it needed was a service and new crystal.
And the finished item:
  • Like 6
6 minutes ago, AndyHull said:
Any idea what the caliber is. I haven't seen one of those before.
I couldn't spot a calliber number, only marking was the *JD on the barrel/train bridge - I included the other pictures I took when stripping down in case you spot anything I missed.
What does it say on the dial, can't make it out.  I like it.
404s have been slim pickin's lately... I guess we had a whole conversation about 500s now, but even then... Us pandemic issue watchmakers have really eaten up a lot of real estate...
There are still a fair few interesting 404 examples here in the UK. I just picked up this 051/0b Kienzle from the late forties or early fifties for ninety nine pence plus shipping.
I think I may have some suitable gold coloured sub-second hands that will fit it (assuming the pivot is still there to attach one).
I can't tell from the pictures if the hairspring is OK, or the balance is sitting square and complete, but for that price, its certainly worth the gamble.
It says Newmark
If you want to know a little more about Newmark (the original, not the new company namesake company set up recently) follow the link.
https://chronopedia.club/Newmark
Managed to pick up this USSR Zim on eBay for only $0.01 a while ago and worked on it this weekend
Here are the before shots:
Balance staff was broken.... and donor #1  had a damaged balance spring...
But Donor number 3 did the trick, finished watch:
I left the patina on the case as it was after a thorough clean in the ultrasonic and then a polish with Flitz as it turned a nice gun metal grey and thought it suited the style of the watch, rather than plating it with shiny nickel.
40 minutes ago, RichardHarris123 said:
Not a football fan but I'm guessing they were pretty dismal.
They played Leeds last week, which is why I mentioned it, and yes, they were.
Edited by SpringMangler
52 minutes ago, RichardHarris123 said:
Originally a Bradford lad. My friends were big fans so I was at a very infamous game.
Sadly, I remember listening to that match on the radio.
  • Sad 1
We were in the paddock, in front of the stands, where it started.  We were pushed onto the pitch, by the time we were out the heat was unimaginable.  I have studded fire engineering and the fire was used as an example.
  • Sad 1
You guys are like rock stars to me. I don't even know where to begin with my petty issues hahah.
I took a look at the "Eros" today. It even got a new old stock strap (new in the 1960s I would guess).
This, despite its size is probably a gents watch and was produced around 1935.
The caliber is likely to be a Phenix 110. although the main bridge shape is slightly different from the one one shown on ranfft.
Clearly a bit of effort was made with the finishing of the movement.
There is a little damage to the plating on the movement and the case, but all in all, it has survived the last eighty pus years quite well.
It runs pretty well all things considered, at around +30s/day or so. The beat error is around 3ms but I left that well alone, as I didn't want to fix it till it was broken.
The mainspring is probably a little tired, but I had nothing suitable to replace it with. I didn't find a suitable small seconds hand for it either, but I will take another look through the stash when I have more time.
Here it is with a couple of other recent additions to the club.
Edited by AndyHull
Working?
Working?
Absolutely. It is sitting a little fast at around +30 sec per day or so. I haven't attempted to do anything about that yet.
I'll wear it today to let the lubrication settle, and finish regulating it tomorrow, but it seems to run without any issues, at least so far.
Those other two, the Kienzle and the Addora also work, but I haven't wound them today.
Edited by AndyHull
    • After another long hiatus (while waiting for truing calipers to arrive), I’ve made some more progress. TRUING IN THE FLAT I was able to use the calipers I purchased to true the wheel in the flat. There’s still a very slight eccentricity in the round, but I’m going to leave it as is. It doesn’t wobble any more and I’m happy with that. Thanks for the tool recommendation @mbwatch. It worked well, though I must say it takes a delicate touch to get the balance between the calipers. Also, my calipers effectively have four different variations based on the orientation of the arms (2 sides, 2 orientations each). Some are more tapered than others, though to what end, I can’t quite tell. My first thought was that flipping them over yields arms that can be used for poising. They are K&D horizontal calipers, btw. OSCILLATION TEST @nevenbekriev @JohnR725 After truing the wheel in the flat, I carefully remounted the hairspring and did your oscillation test. Balance wheel mounted to balance cock, no pallet fork, rotate balance wheel 180 degrees, let it go, and time+count the oscillations. Results as follows for dial down orientation: Duration: 1m 15sec (to full stop) # of oscillations: About 125, though the amplitude of the oscillations decreased significantly, as one might expect I should redo the test in at least two other orientations…Forgot to do that. 🙂  In general, it’s safe to say this watch has a pretty low amplitude, likely for a variety of reasons. I haven’t oiled the balance jewels FWIW…I should probably do that, but I really don’t want to keep disassembling and reassembling the balance. Is it possible to oil those jewels (top and bottom) by just removing the capstones and putting in a tiny amount of oil, with balance in place? I can see how having the pivot in the jewel hole could change how capillary action works, and thus might pull more oil in than desired. However, those capillary forces will be in effect anyway once the balance is inserted. PRACTICE MOVEMENTS @JohnR725 I agree with your sentiment about using practice movements wholeheartedly, and I’ve done that to some degree. The watch I’m currently repairing is for a friend, and she was willing to have me treat it as a “learn-by-doing experience.” With that said,, I probably should have purchased a few more “beaters” before getting to something where I don’t want to muck things up. I’ve still got a couple of those on the bench that I used as donors, and I’ll try to rehabilitate them.
    • Hi, this is the first place I found when looking for advice so I hope someone could advise me.  Im completely new to touching watches but I’ve always wondered how they work.  I’ve bought a cheap movement, an ETA replica to take apart and rebuild.  Im thinking I’ll need some screwdrivers, tweezers, movement holder and a loop? My goal is just to have a go first and see if I enjoy it enough before buying more tools.  Do I buy cheap tools for now and get better quality tools later if I enjoy it like I think I will? or will the cheap tools be a pain and take some of the fun out of it?  With quality tools being relatively expensive I’m unsure what to buy.    Any advice would be greatly appreciated!
    • Yeah I have seen 44-56 documented for Elgin 18 size elsewhere. I have the style of gauge that's like a set of feeler gauges and I never noticed before today it is faintly stamped "Elgin". Pictured is the way I have been measuring. I am going to go to a larger jewel than the 42 that had been in there. I recently won an auction on a big set of Fitrite jewels all in the little bottles, to discover that the what's actually in the bottles bears no relation to the chart of sizes printed on the box. In most cases it seems to be all mixed so in fact I have about 24 little bottles and thousands of assorted jewels of all diameters and lengths, which is better than nothing. But since I don't have a micrometer with a table, measuring for the exact diameter will be a big job. Instead I will test a lot of them in the fork slot the same way I measure with the gauge. But this is still the next thing. I have to get the escapement to unlock first.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
