Well...not so much a repair as made a spare part...and not so much a spare part as a part to replace one I lost due to my hamfisted buffoonery during a restoration!
During reassemby, the tiny ratchet click spring living under the barrel ratchet click flew off & is now probably orbiting one of Saturn's moons. I'll certainly never see it again and it was so small, I didn't even bother to look for it.
So what to do? It struck me that the spring was made of click wire not unlike that of my guitar strings so I snipped a bit of excess off above the tuning peg (for those interested it was the top E string, Adagio light-gauge, I tried the B string first but it was too thick).
Anyway, I was able to fashion it into shape & it works. I doubt if George Daniels would have approved but the watch is an antique Swiss made pocket watch so buying spares was not an option.
So, when you change your guitar strings keep them, you never know when they'll come in useful!post-687-0-63668000-1423687272_thumb.jpg
Nice solution to your missing click spring, I will bear that in mind next time I change my strings.
Now that you have sorted out a replacement you will of course find the original, and it will probably be in plain view as well.
That's a nice movement and a good bit of improvisation Dave, Will our resident guitarist will be proud of you. :)
Nice, musical solution profundus, congratulations on the fix and creativity! Regretfully I play classical so my strings are useless (silk/nylon)!
Excellent tip wish i had thought of this when i needed a click spring for a twin barreled Sekonda , i tried to fabricate one but nothing was suitable , ended up buying a donor movement , i will know what to use next time cheers
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
