Do all quartz movements indicate low battery with the customary second hand jump or do some keep going and losing time until the battery runs out?
In particular I have a Hattori in a watch which is 3 weeks old and in that time it has lost exactly 1 hour. It has 2 year warranty but postage would be more than what I paid for the watch. I'll change the battery and see what happens.
No, they don't all do this.
I suggest that you measure the battery before blaming it. It could be also a lose cannon pinion.
Hi  as jdm explained  not all watches exibit the sweep jumping as a low battery indicator, usually on better quality ones, the lower grade ones just either go down slowly or stop. Check the battery for the 1.55v if lower than 1.3 change it as some don't deliver the power. I have had them stop and a new battery fitted has been going a year later. but some times the watch its self is at fault being gummed up or dirty therefore the watch demands more of the battery witch fails quite quickly, canon pinion , sticky gear train , rotor bearings sticky, or dirty
    • How long had it been without any wind before you first put it on the timegrapher?  Perhaps there was some debris / old lubricant that loosened up while you were waiting to do the 24 hour reading? I recently serviced a Seiko 6319 that immediately after service was absolutely horrible on the timegrapher - 24 hours later (without me doing anything) it was rock solid!  I was a little surprised by this (as I have seen improvements in amplitude after letting it run in but never a watch going from useless to great!). I was suspicious that some dirt must still be in there so I took it apart and cleaned and lubcricated it again and had exactly the same experience - snow storm that after some hours turned into a nice straigh line with good amplitude 🤷‍♂️
    • Yes, I know it was able to run before just enough that everything supposed to be affixed with shellac could fall out. I won't get back to work on this watch for several days at least, but one thing you mentioned about the banking pin adjustments being intended for fork horn clearance got me wondering.... The last adjustment I made to the entry stone yesterday did not solve the problem when the balance is installed. The escape teeth can't quite clear the stone when the balance swings. But I thought it was going to work because manually snapping the fork back and forth did allow the escape wheel to advance almost all the time. I wonder if there's another issue with the impulse jewel, that I have to shellac again anyway. I am going to measure the fork slot and the jewel because I am curious if it is the right size or possibly narrower than it should be. My thinking is if the horn clearance is too great maybe it is not getting enough impulse to clear the escape tooth. But pushing the fork with a tool can move it far enough to clear the escape wheel tooth.  I'll see later in the week. I didn't expect a big challenge from this watch because it ticked for 5 minutes before stopping without shellac. As always I was way wrong.
    • I had one success (and one failure) dissolving a broken stem out of a crown with Alum. The successes was a stainless steel crown and a milder steel stem. A Tag Heuer 2000 Automatic - here with the solution at around 60ºC I could see small bubbles coming up from the stump of the stem and it took maybe 6 hours to disolve I tried to repeat this with another watch and it did nothing.....  This was A Bulova Ambassador with what again looked like a stainless steel crown.
    • That good to know in one way.
