Omega 565 won't tick
Given more time and more practice it'll become easier once you get the feel for it.
Dimensions stated were accurate, and exactly matched that of the old crystal. Regretfully i didn't measure the final dimensions of the new crystal after i had removed material as was sanding and then testing against the case until it went in.
So how did the dimensions stated as 30.1 x 25.3 compare with what you received and how do those figures compare with the original.
Sorry, had to leave for work, will post photo when I finish.
I don't know that yet 🙂 The part that is visible is NOT threaded and much thicker, that's why I'm confused... I'm gonna try unscrewing it and will report back. Thanks for the help so far!
